Washer will not spin
Kenmore washer 80 series model # 110.28803890 will not spin. It does agitate
  • 44 Answers
Possibly the lid switch. UNit fills and agitates but wont move into rinse cycle because timer wont advance as neutral is interrupted because lid switch isnt activated. You can bypass the switch temporarily by opening the console. Depending on how old the unit is either you have to pop end caps or use a putty knife on the front push clips under console to release top. Then look to where white/clear molex attaches to cabinet this is the lid switch. You can strip the ends of a piece of wire and insert it into 2 of the three wire. Colors will be tan ,white,black anything but green. The ground is green, so this will get you bypassed temporarily. Set in spin on timer and watch her spin. Oh yeah stoop dropping the lid so hard and this wont happen.
Posted on May 29, 2009
  • Washing Mach... Master
  • 2,005 Answers
Check your lid switch with a screwdriver pushed into it but, be carefull the switch will now not prevent the tub from spinning
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
80-series w/ broken top agitator
There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the replacement of the agitator dogs, this is a common problem with this style washer.
Mar 28, 2010 | Kenmore Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Washing Machines Logo
316 people viewed this question
Top Washing Machines Experts
