Question about Cameras
I have Image Expert 1.8.5 that was supplied with my Toshiba camera (that I no longer use). Recently the program offered to compress my files (or at least that's what I thought I was being offered). After the operation, the folder "image exepert images" is now displayed in blue. When I tried to back up these files to a flash drive, I kept getting the message: "Cannot create or replace Image Expert Images. Cannot find the specified file. Make sure you specify the correct path and file name." (However, when in the Image Expert program I can retrieve the folder and the images) How can I fix this?
    Novelist:
  • 151 Answers
Try this
To fix this problem:
1. Click on Start/All Programs/ Picture Studio.
2. Select  Image Expert
3. Select  Image Expert Standard. The  Image Expert application will open.
4. Shut down the  Image Expert application and open WorkingArtist by double-clicking on the icon.
5. The problem dialog should be gone.
if this does not solves your problem check out this
There are three known reasons for this error message:
1. The image file is not valid.
Locate the image file and double-click on it. If the file does not open, it is probably not a valid image file.
2. You do not have Microsoft Office Graphics filters on your computer.
WorkingArtist is shipped with a default setting for Microsoft Office Graphics filters.
If you are not using Microsoft Office, you may need to change the setting in WorkingArtist.
You can check to see if the Microsoft Office Graphics Filters are installed on your machine by doing the following:
a. Go to Start/Find/Files or Folders;
b. In the "Search for Files" field, type in: jpegim32.flt
c. In the "LookIn box" select: c:\
d. Click on Find Now;
e. If the File jpegim32.flt does not exist, you do not have the Microsoft Office Graphics filters.
You can install the Microsoft Office graphics filters from your Microsoft Office or Microsoft Word setup disks. Choose the Custom Install. The option that you want to install is called Filters and Converters.
If you do not have Microsoft Office Graphics.
a. Open WorkingArtist;
b. Click on Artist Info/Options;
c. Click on the Artwork tab;
d. Select "Alt Filters" from the Image Display Method Box.
The "Alt Filters"generally work just as well as Microsoft Office Graphics filters.
3. The image file is too large.
We recommend using images files that are under one hundred KB in size. This is a good size for linking to applications and uploading to your website.
If you have larger images, we recommend the following:
a. Create a folder for your large image files. These files can be used for high quality printing;
b. Make copies of the large image files and place the copies in a second folder;
c. Using software, such as Photshop, resize the images so that they are smaller (under one hundred KB). Photoshop has a "Save for Web" option;
d. The smaller images in the second folder can be used to link with WorkingArtistor for upload to a website.
e. For batch resize of your images, check out http://www.digitalphotoslideshow.com
This inexpensive utility has a function that will resize an entire folder of images.
if still the problem.then relaod the softweare agin from the cd.and then check out.this will help you.
thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 29, 2009
What does the positions High,Medium. and Low on photo mode mean?
Without knowing the make and model of the camera this is only a guess, but I would say it's either the image quality or image compression for the JPEG files.
Just about every camera stores photos as JPEG files (many cameras also offer other options, but JPEG is almost universal). JPEG uses a lossy compression scheme. This means that files are compressed to save space on your memory card. This compression throws away some data. Usually this is not noticeable. For example, if one point of a blue sky comes out a different shade of blue (but still close to its neighbors). It would be noticeable if a patch of sky came out green, however.
High image quality applies minimal compression, at the expense of file size. Low image quality applies more compression, saving file space but sacrificing quality.
Compression is the other way around. High compression saves file space at the expense of quality. Low compression gives higher quality at the expense of file space.
Whether these settings on your camera determine the image quality or the image compression, I can't say. You'll have to look in the manual for your camera.
If you require further assistance, please add a comment to this question and specify the make and model of your camera.
Nov 07, 2014 | Cameras
I have a Sony DCR-SR43 handycam. I am a amateur photographer. When i shoot some shots, the file size is very large (208 or so..). Is there any software to compress the file.
The size of the file depends mostly on the resolution. Higher resolution gives more detail and the picture can be printed larger without showing pixelation, but this requires more data, so the files are larger. Recent cameras offer resolutions stated in terms of 10 or 14 megapixels. That much data needs a large file to store it. Reducing the resolution in the camera settings to 5 or 3 megapixels (or less) will give you a much smaller file. In the camera, this will usually be specified in terms of pixels wide by pixels deep (e.g. 1600x1200).
You can reduce the size of a picture in a photo editing program (resize or resample), which will also reduce the resolution.
Compressing the file is not likely to help much. Usually these files are in a format (.jpg) that is already compressed. The camera may allow more than one quality of compression. You can set this to compress the pics more, but this will reduce the quality of the image and introduce more digital noise. It is also possible to increase the amount of compression when saving an edited file in a photo editor, by specifying this at the point of saving. None of these will make as large a difference as reducing the resolution by resizing.
Feb 03, 2011 | Sony Handycam DCR-SR42 Camcorder
HOW TO DOWNLOAD PICTURE FROM EASY SHARE TO EBAY LISTING
Hello Bill,
In situations like this, you will need to get in touch with eBay Image Service team. Please go to this link: https://cschatlb-na.corp.ebay.com/chat.asp?profile=13
Jul 02, 2009 | Kodak Easyshare M753 Digital Camera
Toshiba\corona\start.bg.bmp Not Found.
That is an image file, it may have been moved or deleted, looks like from the file path it's a background image. If you want a quick solution you could just re-install the software. If you're feeling techy go into MS paint (start,programs,accessories,paint) open a new image paint the background black and save it as a .bmp called start.bg then place the file in the Toshiba\corona voila you've replaced the file...
Jan 07, 2009 | Toshiba Satellite A135-S2276 Notebook
Need software for pdr-m25
Sierra image expert 2000 is no longer produced or supported.
For more details, visit www.jasc.com.
Hope this will steer you to what you are looking for !
The Jasc Company has been bought by Corel and you can find the Jasc After Shot (Image Expert 2000) now bundled in their Corel Photo Album 6 available trial offer: -
http://download.cnet.com/Corel-Photo-Album/3000-12511_4-10181959.html
Let me know if this helps you or if you have any other questions.
Sep 28, 2008 | Toshiba PDR-M25 Digital Camera
Image Quality decrease
Um ok. first off, chill with the images being described in inches. The DSC-S40 is way too simple to get lost with. You only have 2 options to play with. One is the resolution which you want to be as high as possible unless you have some special reason for it not to be. Two is you have 2 image quality settings to choose from(Fine and Standard). choose "fine" of course for best results. yes the files size will be a bit larger, but you get the best possible image. Remeber, this is considered a cheap camera, so you want the most it can offer.
Now about the file size anomalies. Dont worry about it. Here is the only conclusion I can come up with that sounds logical. .JPG and most "compressed" image types will never be the same size if taken from a camera unless the same exact picture is shot 2 times in a row very fast witout the camera moving. files size on a compressed image depends on the amount of color variations the camera has to render into a file. The more color variations, the more data the .JPG file contains. It is natural for file sizes from a camera to differ. If you set your camera at 4M and take a picture, and then you set it to 3M and try to take the same picture again thinking it will save space, in theory this is true, but remeber how "compressed" images are rendered. You may have had only the slightest difference of light change on the next pitcture you took . This can have a significant impact on the file size, and can result in a lower res image being bigger in file size than the higher res image. Now, if you are talking a huge difference like 3M@1500kb yet 4M gives you 500kb, then you either have it set to "standard" quality, or you are really lost in this stuff.
But anyway, I hope this is plenty of info. And makes plenty of sense to anyone who understands compressed images.
Sep 04, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Sending photos as an e-mail attachment
When sending photos as e-mail attachments, the image (file) size should not be too large. Use the included image viewing program called Image Expert to save photos in reduced size. For instructions on installing Image Expert, see "Installing the image viewing program" on page 42 of the Instruction Manual. 1. Launch Image Expert. 2. Choose "Open Image" from the "File" menu. 3. Specify the image you want to reduce, then click "Open". If the camera is connected using the USB cable, it is displayed as a removable disc. images on the camera can be opened directly by specifying the remove-able disc. 4. Click on "Change Size" in the "Image" menu. 5. Input values at "Width" and "Height", then click "OK". If "Keep Aspect Ratio" is checked, the size is changed without changing the image’s vertical:horizontal ratio. 6. The image is displayed at its new size. 7. Click on "Save As" in the "File" menu to save the image with the new size.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
RAW quality mode option
In the RAW mode, the image is compiled of raw data with no compression and no enhancing settings from the camera such as sharpness, contrast etc. It provides a higher dynamic range with the maximum image quality without being processed, so the user can apply his/her own changes to the file. The file will have a .ORF (Olympus Raw File) extension. It can be read using a supplied PhotoShop Plug-in or the Olympus Camedia 2.5 program.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Can't place camera image file into another document
Nikon digital cameras record images in the "EXIF" (Exchangeable Image File Format) file type. Even though the file name (when shooting compressed files) ends in ".jpg" it is not a regular JPEG image. This format includes not only the JPEG picture data but also the shooting information (f/stop, shutter speed, lens, etc.) and other text-based data. Writing this type of information is part of the global "DCF" standard for images from digital cameras. Some applications do not properly read this data and will display various errors and warning when opening these files. The only way to use an image in one of these programs is to open it in an image-editing program and save the file to a new file name. This changes the file from an EXIF image and saves it into whatever format is chosen, stripping out all of the extra data. Contact the developer of the program which does not properly open EXIF files for possible updates.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
55 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
