Question about Magellan Maestro 4250 GPS
Magellan Maestro 4250 freezing up
I just got a refurbished Magellan Maestro 4250...Went to test it out and it froze up and rebooted on us 3 times within 30 minutes. How do I fix this or do I need to send it back.
  • alisabeth2 May 29, 2009
    Thanks...will try what you suggested.
I just purchased a referb from TigerDirect and the only issue I discovered was a lockup when the unit goes to sleep. Try holding down the power button for 15 seconds then release it to cycle the unit. Then hold the power button down again for 5 second to start it back up. I had to do this for my bluetooth to work and not freeze up. Now I just turn it on and off manually and avoid having it go to sleep. I also downloaded the firmware update to 4.86, you can download it from Magellan's website. My unit works great so if that doesn't work contact Magellan and I'm sure they will have a solution.
Posted on May 29, 2009
Once I updated my Magellan Maestro 4250 the beginning Magellan screen comes on & the bar at the bottom advances like its loading then it stops and freezes. I've tried reseting it without success...
Try re booting, turn off like normal, then when you go to turn it on, hold power button down all the way through the start up, and 15 seconds more than release the on button, now it's rebooted, see if that helps, let me know.
Jun 11, 2011 | Magellan Maestro 4250 GPS
I tried to upgrade my Magellan Maestro GPS 4250 with the new firmware that Magellan sent. In the process, I accidentally erased all my data in my 4250 and now inoperable. Please help. Thank you.
if you still have the original DVD that came with the device, i think you can use that to upload them maps and other info, but of course this will just be like having the device brand new.
Aug 20, 2008 | Magellan GPS
Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Jun 10, 2009 | Magellan Maestro 4250 GPS
Froze up then black screen
Make sure it is unplugged from external power, then remove the battery, wait 10 seconds and plug the battery back in.  I have had the same thing happen with my Garmin on rare occasions.
May 10, 2009 | Magellan Maestro 4250 GPS
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
There is a RESET button on the bottom of the unit on the left side
Nov 22, 2008 | Magellan Maestro 4040 GPS Receiver
Froze up magellan maestro 4250
I think there is reset somewhere on the unit. Look around. Mine has a slide switch to reset. Try everything. It already doesn't work. Can't hurt it anymore than it is.
Mar 24, 2017 | GPS
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Jun 25, 2008 | Magellan Maestro 4040 GPS Receiver
Maestro 4250
Maestro 4250 is frozen. HELP ;-(
Dec 26, 2007 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4250 GPS Logo
505 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
