Question about Haier 17 in. HDT18PA Built-In Dishwasher
Leaks from bottom
It runs but leaks from the bottom
  • ns090672 May 29, 2009
    Do you have to take every screw out of the back of the dishwasher to remove the service panel. Thanks
  • ns090672 May 30, 2009
    I took the service panel of my haier table top dishwasher hdt18pa to find the leak and it looks like it leaks where the water is going into the bottom spinner. Any solutions. Thanks
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
1.Unscrew the bottom panel, be sure to mark the screws with two different colored markers (i.e red and black), there is 2 set of screws a longer set and a shorter set, mark the holes as well so you know which screw goes in what hole. Be careful with the front panel with the on/off switch, it will come loose, just be conscious of it. Once you open the bottom panel look closely inside, you should see a black rubber plug about 1 inch long that has fallen loose, retrieve the plug. The motor in the middle of the machine has a small outlet pipe that the plug fits onto, just plug the outlet pipe hole with the rubber plug.
2.When putting the the panel's back on be sure to put the 2 screws that hold the motor on first, but do not tighten any of the screws all the way down until you get the screws all in. Finished
Posted on Nov 05, 2009
Not a solution. But i'm having the same problem. I bought this as a customer return. I'm about to throw it away.. Leaking heavily out of the bottom about 30 seconds after you turn it on. i took the back and bottom off but i dont know where to begin to fix it..have you solved anything yet?? ~Beth
Posted on Jun 20, 2009
    Problem Solver:
  • 5 Answers
Pull service panel at base of dish washer and tell me if water is underneath. Should read owners manuel if you have it. most likely leaking from where it connects to kitchen sink or a loose drain hose under the unit. Easy fix if this us the true problem
Posted on May 29, 2009
Garbage disposal leaking on the bottom?
DO NOT RUN THE UNIT UNTIL YOU STOP THE LEAK!!!
Either the sink seal is leaking or the internal motor shaft seal is bad. If it is the motor seal and the unit is more than 5 years old, replace the disposal. Replace the seal only if you have the appropriate skill.
Oct 04, 2014 | Electrical Supplies
My toro 6.5 hp leaks oil at the bottom of the engine runs ok
If this is the vertical shaft motor, there is a seal at the bottom where the crank shaft exits the case. On the vertical motors I've taken apart, the bottom of the case is like an oil pan. It is possible that you could have a crack in the case. But also check the oil drain plug to be tight, but not too tight. This could also cause a crack in the motor case.
Aug 14, 2014 | Toro Garden
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
Why is insinkerator badger plus 5 leaking from the bottom?
Check hose and connection from the dishwasher to the unit. Look for cracks and proper installation.
Apr 22, 2012 | Electrical Supplies
I top off my 1998 Nissan Altime's engine coolant evreyday. Also, the radiator fan stays on for appromiately 2 minutes after I shut the engine off. Is something wrong with the cooling system or the...
The fan running is normal. you need to find where the coolant is leaking. If there are no visable leaks. then suspect the radiator/reservoir cap.
Aug 14, 2011 | 1998 Nissan Altima
During wash or rinse cyle, water leaks from the bottom
open the door,check the rubber boot for any holes,ussually that's where it leaks,also wipe the inside of the door,i've found hair and lint stuck on the inside bottom of the door and water leaks out but pull open the rubber boot and run your fingers all around it to check for any holes.you can remove the bottom panel and then run the machine to see where the leak is coming from.
Apr 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Badger 5 is leaking from bottom of unit... is this repairable? Thanks Chad
If it is leaking from the bottom and not from the top and running down the side then it is only repaiable by replacing the disposal, If it the top leaking and running down the side, then it can be rpaired by replacing the rubber gasket on the top.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
What dose it mean when your washer leaks from the bottom
make sure it is leaking from the bottom!
sometimes there is a problem with the dispenser leaking which in turn runs down the trim of the machine, around the door housing and looks like it's from under the machine - look for evidence of this in the form of run lines from the bottom centre of the door. If this is the case you will need to either clean the dispenser housing or replace it depending on the level of soiling.
If it is an actual leak from the bottom of the machine the you'll have either a perished pipe or work connections
Jun 12, 2010 | Whirlpool WFW8300SW
My insinkerator Badger 5 is leaking from the bottom. It runs, but water runs out of all spots on the bottom; including the ara where the conduit runs into the unit - please help!
My bet is that the garbage disposal in not what is leaking... the connection to the bottom of the sink is leaking and running down the sides of the disposer...
Look higher and you will find your leak..
How is the best way to use a Garbage Disposal
http://www.fixya.com/support/r4062792-best_way_use_garbage_disposal
heatman101
May 04, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Hover steam vacume F5864
Is it running out of the bottom of the tank, or at the bottom of the machine. If at the bottom, you have a water line off. If at the bottom of the tank, there is a water seal that the tank sits on, may have to replace that.
Oct 03, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Haier 17 in. HDT18PA Built-In Dishwasher Logo
490 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Tom Chichester
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
