Question about MotorGuide Standard Motor Replacement Parts - Type: Switches And Compone
I want to wire in a 71lb motor to a Brute 767 head. The 71 has two extra wires than the 767. Everything else has interchanged. The 767 is stuck on high speed. I have changed board, 3 way switch, a
I have a MotorGuide Digital Great White 71 lb 24 volt trolling motor. The forward speed is inconsistant, it will be full speed and then ~ half. When this happens the I have excessive reverse speed AND the "off" position is now reverse. I need to know what the wiring diagram from the motor up to head looks like. Actually can you know the wiring for a 767 Brute and the Great White looks like from motor to the head? Todd
  • 10,865 Answers
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on May 29, 2009
ARE THE VVT SENSORS FOR 1GR ENGINES RELIABLE
are the vvts interchangable from your old engine to new or with wiring diagram can find out why the extra wire i think 1 is for the ecm signal and 2 is for reference and 3 is a ground but not sure you need diagram or replace the head assmbly with old to new its a last hope but check for interchange first
May 26, 2014 | 2007 Toyota Land Cruiser
I got a 1999 motorguide 67lb brute 767 it is 12 or 24v when i swich it to 12 volt it dont work but when i put it on 24 volt it runs but not like it should i need help
My guess is that the motor has leaked water and requires the 'extra' power of 24V to spin it up. To check for a water leak, first remove the prop.
Here is a schematic to get you started:
http://www.mikesreelrepair.com/schematics/displayimage.php?pid=8362
After the prop is off, you will see 2 or 4 bolt heads. You'll need a 5/16" socket. You'll want to remove only one of the outermost bolts. The bolts are about 8" long but only threaded for an inch or so. When you get it out you will be looking for a black, oily looking residue, whch would indicate water still in the motor unit. If you see rust or a white, powdery substance that would indicate there was water intrusion but has since dried out.
Give everything a good clean, replace all the o-rings, clean up the armature commutator (copper brush contact on the armature) and re-assemble.
Apr 01, 2014 | Electrical Supplies
Motors interchangeable
Bad idea to try a different sized motor on that. Everything on the truck is set up for the engine that is on it. All the wiring, the computer-everything electronic. If you went with a bigger motor, the front suspension will also have to be beefed up, as it will be heavier than designed in the front.
Honestly, best and most easiest is to swap in another 4 cylinder motor just like yours, and preferably an engine of the same year-then you won't have problems with electrical connections, with parts in a slightly different place, or any other modifications.
Jan 31, 2014 | Ford Cars & Trucks
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
The switch keeps burning out and the motor turns about one turn and then will not turn again. Motorguide Trolling Motor Brute,767 67 lb thrust 12/24 volt Hyper Drive
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
Jul 01, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
INTERCHANGE MODULE
I'm gonna go out on a limb here and assume you are talking about the band modules, right? If so it will accept some in the 6m,2m,and a couple of the 70cm bands. The model numbers I know it will accept are as follows: FEX-767-2,-6,-70A and -70B. If your module is one of these they are interchangeable. BTW, all of these modules are presently discontinued I'm sorry to say. Hope this helps!
Mar 27, 2009 | Radio Communications
Need to know how to wire a motorguide 767 brute trolling motor
The white wire is the ground. The black wire is neg. and the red wire is pos.
Mar 15, 2009 | Electrical Supplies
Hi, I am installing a new head unit into my dads 98' Buick LeSabre and the factory harness has been cut and I'm not sure of the color code and not sure how to run the extras thru the new head unit and how...
Metra makes wire harnesses for your problem. If your wire harness is, 70-5555 the part that goes into the OEM radio will be 71-5555
Try www.metraonline.com and put in the car info. The harness will come with wire codes for splicing the new plug.
Dec 17, 2008 | Car Audio & Video
MotorGuide Standard Motor Replacement Parts  - Type: Switches And Compone Logo
480 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
