Question about Emerson Pool & Spa
Punp is runnin hot
Emerson pool punp runs for about 30 sec n turns off gets real hot after that
Your thermal cutoff switch is triggering. This is typical of a pump that is overworked, or more often connected to the wrong voltage. Check the wiring to make sure it is right for you incoming voltage.
You can replace the thermal switch, but might as well get a new motor due to the fact that if the switch is tripping it is for a reason
Posted on Jun 08, 2009
  • 105 Answers
Motor has too much drag. hopefully something wrapped around shaft, worst case take motor to graingers and replace just motor
Posted on May 28, 2009
When i start it it idles for 20 sec then dies it will start back up then dies again ?
sounds like a fuel problem Mike. be sure fuel lines are in good shape. fuel filter not plugged air filter is clean. check to see if there is any dirt or water in the fuel bowl. may need to take the carburetor apart and clean real good.
Oct 02, 2016 | Garden
I have a 94 Mitsubishi Diamante ES. A month ago I noticed that transmission was getting stemming hot after driving on a high way. I let the car cool down and then nothing happened for about two weeks....
theres a good chance you need a replacemnt transmission. Since this problem is real your only option to get it professionaly inspected . We can guess, but a guess isn't going to fix it.
Jun 14, 2010 | 1995 Mitsubishi Diamante
My 3/4 HP Emerson pool pump keeps tripping breaker
You did not say what the amp draw was nor what the amp rating on the pump motor was. Also you need to have the running volts tested to see if there is a voltage drop.
May 27, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Using a swimming pool filter system to 'vacuum' the pool floor
i am assumming that you have a sand filter,to clean your filter, 1st put it on backwash and watch the little glass bowl till it run clear,45 sec. or so then turn off power, turn valve to rinse, turn power on. watch little bowl till it runs runs clear 30 sec. or so.to vaccam turn handle to waste turn power on. hope this helps
Aug 08, 2009 | Intex 1500 Gph Swimming Pool Filter Pump...
Water loss in pool, but no hole in liner
The only problem is that ther is a leak in the liner. Generally at the bottom where a rock or debris has made a small hole. They can be patched but the pool will need to be drained. Call your local pool service company.
Kurt
Mar 23, 2009 | Intex Frame Set 12 ft x 30 in Pool with...
Pool & Spa Logo
272 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
