Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Makes very little ice, chg filter lite stays on-2 days old!
New fridge, Samsung RF265AB. Since it was set up yesterday, very little ice has been made, AND the change filter light stays on, even though it's new. The instruction manual has virtually no information. Just wondering how normal this is....the set up guys left a small dent on one of the front doors and Sears has offered to replace the entire fridge (silly, since it's just a door), or give me a $100 gift card to compensate for the dent. But, if the ice and filter light issues are not normal, I'm thinking I an entirely new unit is wise.....Thanks! we have a ice maker problem it makes ice good for a couple of days then it stops and makes lots of noise when trying to drop ice. i have the RF267aa
  • 21 Answers
Take the deal!!! Let Sears install a new unit! Gregg
Posted on May 28, 2009
2 Suggested Answers
danforddan1
  • 192 Answers
SOURCE: makes very little ice, chg filter lite stays on-2 days old!
Check that the valve to the H2o supply is turned on full tilt, check for kinks in the tubing hopes that helps DFD
Posted on Apr 11, 2009
Should I buy a Samsung 26 cu. ft. french door fridge with ice maker on top?
hey there, it depends on your budget and what fits in your kitchen, my self have a
Samsung RFG23UERS1 fridge and i am very happy with that one, so like i said its up to your budget and if it fits
Nov 25, 2013 | Refrigerators
I have a subzero BI42 SD fridge. Just replace the water filter. It now does not make ice. Turned on the icemaker but get a blinking ice indicator on the control panel. Looked into the trouble shooting...
this is abrand new fridge.if the ref is less than 2 yr old. better call a tech. your problem FOR SURE. water valve, ice maker, or a combination of 2. also tell your tech. to check the arm in the i.m. and the brackett. do not trty to replace the ice maker. is a little tricki.(SUBZ.less than 2 years old is cover by the manufactor subzero. zero money for you.)
Apr 19, 2010 | Sub-Zero Bottom Freezer Refrigerator
Ice maker stopped making ice yesterday. I changed the water filter, but it still hasn't done anything There are no ice cubes jammed.
the icemaker line from the basement to the fridge may be bad, clogged or the little fitting they put on the water pipe to connect the plastic line to your fridge could have sentiment in it, clogging the water. Ice Maker needs a certain amount of pressure in line to work properly!
Dec 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
Samsung RS267 Icemaker too slow - not waterline
Hthere........sounds like your settings are all askew.....however help is at hand....simply log on to ww.samsung.co.uk (if your from the uk) go to product support.....enter your model number....and hey presto they present you with an online manual which you can print
regards Sir Galahad
Aug 16, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Aug 09, 2009 | GE Refrigerators
I just bought a new one and plugged it in about 2 hours ago. when does the ice maker start to make ice?? and what is the correct temp for the fridge and freezer to be at??
it will take a little while for the ice maker to get the air out of the line so it can make ice. Start with the middle number on the temp guage and adjust after a few days if necessary. hope this helps :)
May 04, 2009 | Samsung Cell Phones
Apr 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
422 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
