Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
18hp v-twin won't go to full RPM but runs slow and misfires...
I got a used mower (sabre by John Deere) that ran good there at where I bought it, but when I went to mow there was no fuel to engine. Found the float stuck and got it going. A week later I went to mow again, and now the gas ran from the carb and it only runs slow, and acted like it was choked. I tried the float thing again but broke the post holding the float (bought a new carb and fuel solenoid) Now it acted the same way, but ran faster when I pulled one of the spark plug wires off, so I examinedthe plugs and one was dirty, one was wet only. I checked for spark with each plug pulled out of its hole, and there IS spark, but when assembled, it backfires and spits some fuel out into the air filter.
I wonder if the timing is electronic and is going bad?
Any ideas?
    Problem Solver:
  • 15 Answers
Yes had a B&S v-twin do the same thing. the one plug dirty and one plug wet is a red flag. remove both plugs and put a screwdriver in to touch top of piston. turn engine with your hand and see if screwdriver moves. i'm guessing one of them won't, and that means one of the connecting rods has exploded, the crank is ruined, and someone sold you a lemon.
Posted on Feb 10, 2010
GOOD MORNING, I HAVE A D140 JOHN DEERE LAWN MOW,IT RUN WELL WHEN NOT MOWING BUT WHEN ENGAGED IT SLOW DOWN AS THOUGH IT HAS TO CATCH IT'S BREATH LESS THAN THREE YEARS OLD
Make sure there isn't anything binding the deck belt or blades. Check the spindles for free movenent. If all that is good then it might be the linkage that is supposed to adjust the throttle when the engine is under load or it might be a carb issue...especially if you run ethanol gas in it.
Aug 27, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Oct 25, 2012 | John Deere Garden
Sabre 17.542hs loss of power
you could have a weak coil and misfiring under a load each cylinder has it own coil on that engine you can get a inline spark tester to see
Sep 03, 2012 | John Deere Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
John deere L120 riding mower with IntekV twin 22hp
Try replacing the gas in the fuel system. The manufacturers are telling us that gas over 30 days is considered bad gas.
Good day.
Nov 02, 2009 | John Deere Garden
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
635 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
nirodacyar
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
