Question about Mitsubishi WS-55859 55" Rear Projection Television
Power was off
The green timer light keeps blinking and will not reset blinking for 2 days will not reset
  • 80 Answers
You need to replace 4 capacitors on the DM board. It is located inside a metal box on the left side of the set, looking from the rear. The original parts are 1000uf 16v. You will need to install 1000uf 25v or 35v. They are located at the top of the board and are green colored.
Posted on May 31, 2009
  • 1030 Answers
SOURCE: Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Posted on Jan 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: green timer light blinking constantly, no picture
You need the V21/V19 DM repair kit thats available at the following link, it contains the parts and step by step instruction CD so you can do the repair yourself. Its listed under their repair Kit category.
http://servicemanuals.vstore.ca/
Posted on Aug 23, 2008
ginko
  • 19396 Answers
SOURCE: I UNPLUGGE MY TV FOR 2 DAYS AND PLUGGE IT ON BACK
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
toolkits
  • 1099 Answers
SOURCE: mODEL ws55511 AFTER POWER SURGE, GREEN TIMER LIGHT
hello,
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
Posted on May 25, 2010
toolkits
  • 1099 Answers
SOURCE: won't power on
hello,
I am unable to reset the timer after replace projector lamp- there are no screen. How to reset the timer?
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
PG-MP60X - Power light is red, lamp light is red, projector not working. How I can fixed that ? thank you
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Mar 04, 2014 | Sharp PG-M60X Multimedia Projector
My projector wont turn on and the lamp light is flashing but i got a new lamp at the start of the year
Have a nice day!
Jerry
Lampdeng Limited
Nov 12, 2010 | Sharp BQCXVZ100001 Projector Lamp for...
I have a sharp projector RX30X the stand by light still red it doesn't blink and the device doesn't work what's wrong?
Have a nice day!
Jerry
Lampdeng Limited
Jun 02, 2010 | Sharp REPLACEMENT LAMP FOR XR30X/30S/40X...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Dec 17, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Nov 09, 2007 | Televison & Video
Mitsubishi WS-55859 55" Rear Projection Television Logo
234 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
