Setting the NIC card to 1500 will NOT change anything at all if your router is set differently. I have the same router and there is no way I can change the mtu that I can find. Speedguide says my mtu is 1492, but I do not have a dsl line, I have cox cable. My connection is manually set for 1500, but the router appears to be overriding that, even though it's set for dynamic, not PPPoE. I'm running Vista 64 without autotuning.
4 port router - easy install wizard step 1 - 'multiple network adapters found - choose from list'...
(More)
4 port router - easy install wizard step 1 - 'multiple network adapters found - choose from list' but there is no list and cant go any further. Using Vista.
I also have a belkin wireless router but when I try to connect my IBM to the wireless it says it...
(More)
I also have a belkin wireless router but when I try to connect my IBM to the wireless it says it isn't validated....My PS3 work fine on the wirelsss but my IBM gets the connection but no validation?
trying install belkin n150 router.setup router and cables as setup guide instructs.i run cd but...
(More)
trying install belkin n150 router.setup router and cables as setup guide instructs.i run cd but programe will not find connection to router.i played with connections and it showes i use wan miniport pppoe.not lan
When I hooked up my N150 router, the router light is steady green&modem light flases...
(More)
When I hooked up my N150 router, the router light is steady green&modem light flases amber,no other lights come on.
