Wahing machine problem
Whiripool washer lsq9544kqo womt pump out water or spin
  • Collegeless May 11, 2010
    Have you checked out the lid switch
    Genius:
  • 1,122 Answers
Bad lid switch,you can bypass it by putting the pos.neg wires together-mike
Posted on May 30, 2009
Water womt drain.
Had possibly the same issue. Mine would do spin cycle but, not drain. I had to remove the hose on the pump and had cotton stuck inside it. My brother had a sock stuck in his. I was told its a common problem. I'd check that first. Hope this helps.
Aug 18, 2013 | Washing Machines
Maytag washer fills and washes but doesnt rinse or spin.
i would check your water level switch function, it will be located at the end of a 1/4 inch flexible tubing coming from the washer drum, my past experience indicates the replacement of this assembly will restore operation to your unit.`
Apr 16, 2012 | Maytag Washing Machines
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
All of my washing machine's "FUnction" buttons do
Change the program controler unit /the board if you need to get access to all the programs.
Remove the controller unit and make sure that the connectors are tight. Make sure the water level sensors , the door switch is working.
If there is no result the program controller is a suspect.
Jan 21, 2011 | Samsung SW62ASP Top Load Washer
Wahing machine does not spin
the coupler is bad, this unit does no have a belt. has a motor coupling installed.
i have seen video's on youtube about how to do this in the past, its not hard
part number 285753A buy it here http://lartoday.com/order_parts.htm
lebarchrigen appliance repair
www.lartoday.com
Dec 10, 2009 | Whirlpool GST9679P Top Load Washer
Awm 5125 front load womt spin
Check the agitator(the big plastic piece in the center)you can remove the cap in the top and there will be a bolt that holds it on,remove the bolt and see if the plastic gears are worn out.
Please rate this solution
Jan 20, 2009 | Whirlpool AWM5125/1 Front Load Washer
Inglis Washing machine not spinning
DID YOU REPLACE THE THRUST BEARING LOCATED UNDER NEATH TRANSMISSION, PLASTIC AND ROUND THAT BELT GOES ONTO ,, THAT SHOULD FIX UR PROBLEM
Nov 29, 2008 | Washing Machines
Wahing machine kitchenaid won't completely drain water
Check drain pump for any blockage.Pump accessible by removing lower panel,on bottom front of machine.Also try liquid instead of wash powder,and make sure that you are using automatic powder as other will foam in machine.
Apr 01, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
140 people viewed this question
Top Washing Machines Experts
