Question about Cobra Radio Communications
Cobra Mirco Talk CXT 195
USB charging capability is not working with computer as it is not charging. Battery indicator is still flashing low.
    New Friend:
The Flashing "1/4 Battery" indicator is not a "Battery Gauge". It is a Low Battery indicator. When you charge your system overnight, it will continue to flash up to 5 seconds after you unplug your handi-talkie. This is normal.
The flashing 1/4 battery indicator will flash the whole time you are charging.
Posted on Jun 12, 2015
  • 91 Answers
Pls check usb cable , replace with new gud quality short length usb cable n try to connect the same in back side USB port not front side ..
Posted on Jan 19, 2014
4 Suggested Answers
no8rf
  • 6 Answers
SOURCE: My cobra micro talk model FRS 130 does not work
take it back
Posted on Nov 15, 2012
robertlyoung
SOURCE: Manual for Cobra Micro Talk CXT 275 Manual
I have this manual. I looked online at the Cobra site for a digital copy, and the manual for the CXT225 is a very close match. I checked it page by page and only found one small difference in the section on charging the battery. (Don't leave it on the charger more than 24 hours). Here's the link to the CXT225 manual: https://www.cobra.com/downloads/manuals/CXT225_MANL.pdf
Posted on Nov 03, 2012
  • 50994 Answers
SOURCE: Cobra micro talk won't charge?
Could be batteries need replacing or the charger may have failed
Posted on May 15, 2013
Garage sale bargain!! NO Manual Guide Book for Cobra Micro Talk -CXT 195.. Please advise where to get one. Thank you
Many Cobra two-way radio manuals are available from the manufacturer: https://www.cobra.com/support/product-manuals . Use the drop-down menu to select two-way radios. I found the CXT195 on the sixth page of these manuals. The direct link to the manual is https://www.cobra.com/sites/default/files/manuals/CXT195_MANL.pdf .
I hope this helps.
May 30, 2016 | Cobra Radio Communications
CXT 195. What amp charger to use?
Do you mean 145? I cannot find a 195 on their web site. The CXT 145 comes with a USB Y charger cable, designed to charge off a USB port. Use a high output USB adapter. Amps of 1 to 3 should work fine. You are using rechargeable NiMh batteries and they do not care as long as it is at least 1 amp. Higher amp will charge a bit faster and make the batteries hotter.
Aug 01, 2015 | Cobra Radio Communications
What charger do I use on my cobra walkie talkies model number cxt 195
Any micro USB, or take out the batteries and use an external charger.
Can a Motorola talk about 250 talk to a cobra CXT 195. They can hear me from the Motorola I just cant hear them
Your code (PL code, interference eliminator, quiet call) is not programmed the same on both radios. The Cobra appears to be set to open squelch (no code). Set your Motorola code setting to zero (off). This should solve the problem.
Feb 18, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
Batteries only hold charge for hour or two
put in different brand batteries.Use name brand not the cheapo's
Jan 20, 2014 | Cobra Radio Communications
Oct 25, 2012 | Cobra Two Way Radio
Package, manuel and receipt were accidentally thrown away and we don't know how to charge the radios. They work, but are running low on battery power! They have a power supply cord that you plug both...
From what I just read on the Cobra website, you may be misinterpreting the battery indicator lights:
My radio keeps showing low batteries
This may simply be a matter of misinterpreting the low-battery indicator. We use two different types of battery indicators:
  1. Battery Level Indicator: This battery indicator is always visible, and has several segments. When all the segments are lit, the batteries are full. When only the last segment is lit, the batteries are almost exhausted.
  2. Low Battery Indicator: This type is usually NOT visible. It only appears when the batteries are low, at which time it flashes on the display to warn you of a low battery condition.
Please note that when you turn on your radio it first performs a display test. Everything on the display will light up for a few seconds, including the Low Battery Indicator. This does not mean that the batteries are low. After a few seconds the display test will end, at which time the Low Battery Indicator should go away.
Here is a link to the Manual for your radio:
https://www.cobra.com/downloads/manuals/PR260WX_MANL.pdf
It is a PDF file, which requires that you have Adobe Reader or equivalent installed on your computer for it to open and display properly. If you don't have it, it can be found here (it's free!):
http://get.adobe.com/reader/
Jul 16, 2011 | Cobra microTALK PR 260-2 WX Two Way Radio
My walkie talkies will not charge wheni place them on my charger, whywont it work
If neither of them work, then that would suggest something common to both... the Charger? Are you sure it is OK? Is it making good connection, give them a clean/scrape. Otherwise it could be dicky batteries, they go faulty all the time & for no apparent good reason.
Feb 09, 2010 | Cobra Electronics CXT85 Two Way Radio
Radio Communications Logo
2,651 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
