I have a Benq fp 767 monitor, but it won't pnp with my WinXp PC. It powers on, then the screen just flashes. Wont autosync. Where would I go to download the drivers and/or software if needed?
  • 70 Answers
You can download the drivers for your monitor by going online from the website www.driverpool.com their you have to select your monitor model and download the drivers
Posted on May 29, 2009
Benq lcd fp0537s on for just 2 second
There are one or two capacitors in the power supply that open," leaving a slight puff at the top" in some cases.
Mar 16, 2012 | BenQ FP92W LCD Monitor
Trying to purchase a power adaptor for benq fp781 can only find one compatable for fp 791 would this work on a fp 781 monitor ??
On the screen itself, where it plugs in, it should give you a voltage rating, and a line with a C encompassing a circle. Make sure that these two things match up between the two screens, they should, but at the same time, there is the possibility that they don't. Also, make sure the plug is the right size. Yes, it should work, but I would just take the extra precautions listed above to prevent frying your monitor.
I hope this helps!
May 04, 2011 | BenQ FP781 17 in. Flat Panel LCD Monitor
No display
BenQ made a lot of monitors for Dell. You may want to look at Dell pictures.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 11, 2010 | BenQ FP757-v2 - 17" LCD Monitor
Benq G900W Monitor: Settings show as generic non-PnP monitor and
for that purpose you have to insert an AGP card into AGP slot of grade 8X then you can see full resolution because the inbuilt display card does not support to high resolution
Mar 05, 2010 | BenQ G900W Monitor
How do you remove the stand from a BenQ 767?
remove screws either side where stand go into back of monitor.
then slide stand toward bottom of monitor and it should slide out
Jan 14, 2010 | BenQ FP767 17" LCD Monitor
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
Wont power onPressing power switch, blue light comes on, the BenQ logo briefly flashes then screen stays black
Power leak causing overload on the O/L sensor.
Probably a faulty capacitor on the power board
Sep 07, 2009 | BenQ FP71E 17" LCD Monitor
Check to see if the video cable is connected at both ends securely.
Also, if possible, try another cable.
Jun 09, 2009 | BenQ FP71E 17" LCD Monitor
Benq monitor flashes off and on
It has a large capactor inside that is leaky, needs changing. In powersupply.
Sep 14, 2007 | BenQ FP737S-D 17" LCD Monitor
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
