use the following ideas
As with many small appliances, regular maintenance makes a dramatic
difference in how trouble free your electric iron will be. Even so,
things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the
electrical cord, and check the thermostat (see the
Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and
clean the vents (see below) and flush sediment out of the steam chamber
(see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the
iron stains fabric, clean the soleplate, clean the tank with a
commercial cleaner, and use distilled or filtered water.
God bless you
