Question about Sharp Office Equipment & Supplies
Sharp AR-157E unable to copy
"L" and "1" continues to blink back and forth on display panel. Unable to select paper tray choice after copier is warmed up, unless copier is initially turned on then tray choice can be selected. New toner cartridge has been replaced. Thank you.
    President:
  • Sharp Master
  • 990 Answers
Hello sir; Check the scaner unit, when you make copy does mirrow move out and return to home if not check the mirrow motor or cable.
Posted on May 29, 2009
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
Nov 01, 2013 | Sharp AR-M205 Copier
Sharp 157e H4 blinking,where is the fuse and or thermostat to check. This Church copier is 6 years old and paying a technician several hundred dollars to come out to fix it is crazy. Do you have any...
Push the 'clear' button and then the 'auto' button then the 'clear' button and then the 'auto' button again.This should be done as quickly as you can and the console will go blank.Next,select 14,which is the low temp clearing code, and then push 'start' and then turn the machine off and back on again.
Aug 09, 2011 | Sharp AR-157E Copier
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
Copier Sharp AR-M237 a Misfeed Occurred message
First try a different tray to see if it works, if it does than the paper tray you are using may have dirty feed tires or look for something obstructing it.
Mar 24, 2010 | Kyocera CopyStar CS-3060 Black and White...
Sharp AR-M237
please clean the sensor and feed the paper
Mar 17, 2010 | Kyocera CopyStar CS-3060 Black and White...
Can you bypass a low toner alarm on a AR 157E to allow the unit to run paper through the paper path
Yes in service mode. But you will not make a copy with out any toner in the copier.....
May 06, 2009 | Sharp AR-157E Copier
AR-157E blank page when using automatic feeder.
you night check to see if your cable to the copier is connected but this problen iv seen several times not worth fixing the main pcb is usally gone as for as working with the feedder
Feb 17, 2009 | Sharp AR-157E Copier
Indicator light
Do you mean the bypass tray is selected? if so just press the tray selection button until the tray you require is highlighted. Read the manual.
Jul 25, 2008 | Sharp AR-207 Copier
Sharp AR-157E digital copier
sir i have a problem with sharp AR-5320 copier it blinking H and 4 can you help me please
Jan 15, 2008 | Office Equipment & Supplies
89 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
