Question about Dometic Rooftop RV Air Conditioner
No power to thermostate on Duo Therm 15000
I have a duo therm 15000 btu on my Airstream. From one day to the next the thermostate stopped working. I replaced the thermostate and it still won't come on and turn the ac on. I checked and I have power running to the a/c . It's just not getting thru to the thermostate. Any ideas ?  Thanks, David My air conditioner will not come on. No fan, no hum, nothing. The thermostat works fine for the heater....just nothing for the air. Could it still be a bad thermostat?
  • steve
    steve May 11, 2010
    Either the stat or the stat wires.
2 Suggested Answers
meBNme
  • 334 Answers
SOURCE: no power to thermostate on Duo Therm 15000
Look for a small fuse somewhere in the control panel. Usually a blade type (car) fuse 3 to 5 amp. Chack to see if its blown. If you have no fuse, or its NOT blown. Check to see if you have voltage comming out of, and going into the transformer.
Thsi is where you would START to diagnose the problem. Check this and we can go further.
Posted on Jan 18, 2009
What refrigerant in a 08 Duo Therm Briskair 15000 BTU
If you look at the data plate on the outdoor unit it will say. Otherwise need model number
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 11, 2017 | Heating & Cooling
Why am I not getting power to ac capacitor?
A thermostat or a relay activated by the thermostat turns power on to the capacitor for the compressor.
May 03, 2015 | Dometic 459196 Duo-Therm Brisk Air...
How do I Wire a duo-therm RV heat pump
see wiring on panel make sure dip switches correct
Feb 26, 2015 | Dometic 459196 Duo-Therm Brisk Air...
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Have a Duo Therm 59516.531 15000 BTU blower motor does not run checked cap 5mf ok tried direct power still nothing any thought. thanks
if you tried direct power and still nothing then your fan needs to be replaced . there should be a a/c supply store near you . get the model - serial number on the fan or the unit itself to get the right fan for your unit . hope that helped
Jul 01, 2010 | Dometic 57915531 Air Conditioner
Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Aug 22, 2009 | Heating & Cooling
Jan 18, 2009 | Dometic Rooftop RV Air Conditioner
Penguin Duo therm AC bogs
Try replacing the wall thermostat with an electronic unit. It sounds like it is short cycling. If there is not at least 5 min delay before trying to restart the compressor this is what happens. Most electronic thermostats have a delay feature built in to solve this problem.
Jul 08, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
203 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
