Question about Toro Lawn Mower With Toro Power Tools
Toro 20016 engine surges up and down - then stalls
My Toro 20016 mower enging surges up and down for a few minutes and then shuts off. After it shuts off the throttle is pinned wide open on the top of the carb - seems like the governor arm is forcing it to be wide open. Any ideas of what is going on?
  • cwkran2 May 30, 2009
    I have a float style carb - so is there a diaphragm involved? What specific tips can you provide on cleaning and setting any adjustments on the float-style carb?
  • Jim Carlton
    Jim Carlton May 11, 2010
    sounds like the choke is stuck on
  • 1,040 Answers
You have carburetor problems. Chances are the diaphragm needs to be changed and the carb. needs a good cleaning. If you need tips on carb. cleaning, let me know.
Jim
Posted on May 29, 2009
  • Jim Parker
    Jim Parker May 30, 2009
    I doubt that it has a diaphragm. You need to disassemble the carb. and clean all small portals with a Den Tek Brush, (used for cleaning teeth). They work great for this. Also clean the jet (in carb.) with this brush. Replace any gaskets if need be. You don't want air getting in the carb. through a leaky gasket. Once the carb. is clean, check the spring on the governor and make sure it is attached and movig freely.
    Jim
  • Jim Parker
    Jim Parker May 31, 2009
    Thanks for the rating cwkran2. I don't think there is a setting for the float. If you are still having problems, you may have gas leaking from the bottom of the bowl on the carb.. There should be a spring on the bottom of the carb.(bowl) with a screw type pin.The spring may be worn out, causing it to leak gas.
    Jim
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
How to change the drive belt on a Toro 20016 SP Mower
The Toro 20016 mower is a front wheel drive mower and fairly simple to change the belt on. Start by disconnecting the spark plug to prevent start ups while working on the machine.
Remove the blade and adapter. The adapter includes the pulley for the belt.
two screws under the mower, with 3/8 heads hold the black cover over the belt. remove the cover and now you will see the transmission
The transmission, depending on the year of your machine will have a guard holding the belt on. Bend or remove the guard to remove the belt. Install you belt in reverse order.
You can get parts and special tools like the blade stop at a store like www.arcolawn.com
Feb 23, 2011 | Toro Lawnmower Lawn Mower Sp Drive Belt...
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
My Toro 20016 will start but will only run for a minute. If I hold the primer button down all the way it will continue to run but will die if I release. I have cleaned the float and there are no leaks in...
You will need to clean out the jet on the bottom of the carburetor. The fuel is not being sucked in to engine. Check the needle and seat to make sure fuel is flowing in to the carburetor.
Jul 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro mower-shut off, won't re-start
check the coil by pulling the plug and lay it against the head put the plug wire on pull the handle if it sparks then its not the coil another thing you can try is spay carb clean or starting fluid in carb see if it starts if that starts it then the float in the carb is stuck if i can help further e-mail me @wadembly@aol.com
Jun 08, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 hp 9 year old mower. Starts Ok; surges
Sounds like your carburetor needs to be cleaned out. The surging is usually a sign of running to lean (not getting enough gas) because of possible water, rust, gum, varnish or trash in your carb. Hope that helps.....
May 17, 2009 | Toro Lawn Mower With Toro Power Tools
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,432 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
