Question about HP Officejet 5610 All-In-One InkJet Printer
My printer has worked fine for months. Now it says it's "offline"? I have several documents in the print que but it won't print. any ideas? thanks
My printer has worked fine for months. All of a sudden it won't print and it tells me its "offline"? I don't know if my son did something to it.
  • 90 Answers
Check the connections it just means the computer can't see the printer. It is probably the USB cable
Posted on May 28, 2009
Wireless printing doesn't work
Is the printer set as default in the printers? I need more info to give a solution. Is the printer offline? Try to delete the printer and re-add in software. What message do you get when you try to print to printer? Are your documents in Que to be printed? If so Delete /cancel and try to print again.
Nov 02, 2012 | Acer Aspire One PC Notebook
Why is my star tsp-800 thermal printer offline?
Hi Valued Star User
Please try restarting the computer, this will reset the printer spooler, clear any existing print document and should mean the printer comes back online.
I hope this helps.
For further help please contact us at: support@star-emea.com
Best regards
Star Technical Support
Jan 31, 2012 | Star TSP-800 Thermal Receipt Printers
HP 1315xi psc all in one error offline
Go to Control Panel- Printers
Right-click on your printer and click on Use Printer Online.
Hope this helps!
Aug 03, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printer status- error offline
first go to services.msc refresh the spooler service. then insert the printer disc in to the computer . do a level 2 uninstallation .
restart the computer then again again reinstall the software issue will resolved
Que proplem
There are two things you might be missing.
Both involve getting into the printer que.
It sounds like you already know where that is. If not, open your start menu and go into control panel then click into the printer section and double click the printer that is giving you trouble
once open look at the top of the que window and see if it says Use offline after the printer name. If it does, click on the printer drop down menu. and it will also have a Use offline option which will have a check mark beside it, click it and the printer will go back online.
If this is not the case you may have a document jammed or the print spooler is locked up.
To release/cancel a jammed que, look at the first document in the que and if it has an error of any kind in the status column you can right click on the name of the document and then select cancel from the popup menu. If there's no error message or if that doesn't work your print spooler may be jammed up. This can happen for a host of reasons but is simple enough to check.
close the que and go to your My Computer Icon, Right click it and then select manage, If you're using Vista then a continue window will pop up, select continue. When the management console opens, hit the plus sign/arrow near the bottom for Services and Applications then select the sub category services. A full list of Services will come up on the right hand side. Double click Print Spooler. Now Click stop, this will take a few seconds. Once it's done close the windows, and shut down the computer, once it's off, turn the printer off for 10 seconds and turn it and the computer back on. You will need to go back into the services list, double click print spooler again and make sure it is started.
Now go back into your printer que and make sure it's empty, right clicking and deleting anything that survived the restart. If this works the printer should start working again. If not at worst you may need to uninstall the printer and reinstall it.
Hope this helps FixYa
Chris
Apr 27, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Print not working on my brother MFC-665CW
Do you have several attempts showing in your print que? Go to control panel, then printers, the double click on your Brother printer icon. See if there are documents stacked up. If they are, Windows will not send anything to the printer until all documents are printed in order. I hope this fixes your problem. Thanks for using Fixya.com
Jan 26, 2009 | Brother Multi-Function Center MFC-665CW...
Printer not printing documents in que
my printer hp psc1315xi all in one printer copier, scanner will not print any documents, not even a test print, there is also a doucument in it that am not able to delet from the printer
Jan 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer message says it is offline
Hi
Kindly check the usb cable if its fine then try going into control panel open printer and faxes option & set your printer as default .
Thanks
Jan 03, 2009 | Brother HL 2140 Laser Printer
Wireless printer doesn't print (HP LaserJet 1320 NW)
GO TO PRINTER MENU AND CHECK THE JOB IN QUE AND CHANGE FROM OFFLINE IT TURNS TO READY
Nov 25, 2008 | HP LaserJet 1320 Printer
Will not print more than 1 page
HI there change the data cable or set the driver bi-directional printing off try this should work let me know.
Thanks J
Jan 21, 2008 | HP LaserJet 1000 Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
383 people viewed this question
Seeker5211
Seeker5211
