Unmountable disk volume
I'm installing windows xp sp2 to a brand new desktop.
a blue screen appears with this message. "unmountable disk volume".
i think i need a SATA driver. where can i find this driver?
can't find it on the ecs website.
motherboard: ECS 945GCT-M2/1333 V1.0a
  • 104 Answers
I do not think that you need a "driver"
I would like you to click here for more info on your problem
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Posted on Oct 22, 2007
    Scholar:
  • 51 Answers
You may want to start with this
I'd try a website like http://driverscollection.com .. for others Google SATA driver ..
Good luck.  Love those blue screens!
~kerry
UNMOUNTABLE BOOT VOLUME ERROR ON GATEWAY GM5045E WITHOUT RECOVERY OR WINDOWS XP DISC.
An unmountable boot volume error suggests that you may have a hard disk failure or at least some corruption to the hard disk which the system uses to boot Windows XP.
To try to resolve this problem you would need to use a specialist boot CD to try to repair the disk errors. One such disk is Hiren's Boot CD which can be downloaded as a CD image file (.ISO) then would need to be burnt on to a blank CD then the computer booted from this CD.
On the initial Hiren's boot menu, select DOS programs, then select Disk tools before selecting HDAT2 to perform the disk repair actions.
HDAT2 can take some time to complete depending on the size of your internal disk drive and the number of bad sectors or other errors encountered - the tool will attempt to repair bad sectors by reading, verifying, writing and re-reading / verifying the data.
If the disk can be recovered, then you may be lucky and the system will be able to boot but otherwise, you may still need to do some further recovery work for the operating system, in which case you may need a Windows install CD or other recovery CD media.
If HDAT2 finds a lot of unrecoverable errors then you should seriously consider replacing the drive - you should be able to recover data from the old drive using other tools on the Hiren's Boot CD, including booting the CD mini-XP environment and using the tools there too.
Dec 29, 2011 | Gateway GM5045E (RBGM5045E) PC Desktop
How can i install windows xp when screen showing blue screen
Check whether you have installed the SATA Hard Drive driver using a Floppy disk. Some Computers needs SATA Hard Drive Driver before installing the Windows XP. Try using Windows XP SP2 disk.
Jul 01, 2010 | Compaq Presario 700 470024-192 Notebook
Unmountable boot volume
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
Oct 05, 2009 | Dell Inspiron 1525 Notebook
Unmountable Boot Volume BSOD
0xED is not just specifically present on HP computers but all PC-based computers which has XP or later using NTFS on it. It can be resolved by doing a chkdsk /f /r or by performing a repair installation using windows. This is caused by software corruption (which is repairable using the steps aforementioned) or hardware failure, which may lead to OS reinstallation or harddrive replacement
Jun 10, 2009 | HP Compaq Business nc8000 Notebook
I canot install windows xp to acer aspire m1621
your copy of windows xp must have sata drivers embedded into the installation disk. the system is not a eide.
Mar 29, 2009 | Acer Aspire M1641-U1521A PC Desktop
Disable sata in bios of compaq CQ40 laptops
i m not able to install windows xp on my compaq cq60 104tu laptop
when i boot the cd the exatrating process work properly and after extraction of all file when windows is startup a blue screen appears and
and message displayed in the screen check ur hard disk for vireuses
and installation stop
Dec 20, 2008 | Compaq Presario Notebook
XP wont boot not recognising Sata hard disks
if you want to try and get to those files you have best buy another drive and load windows on it . then connect this drive using an external usb adapter/enclosure, not before , not during , only after windows is installed and then you may get to this drives data .if you have luck.
or purchase an enclosure and connect to another computer.
at most you should attempt on this drive is to boot windows and run a repair on the drive. even that can be risky without backed up data.
Mar 22, 2008 | Computers & Internet
Hi everyone...my windows xp wouldn't start up at all..(unmountable boot volume).kept restarting with the blue screen...I had ** xp disk (came pre-installed)....finally was able to get to my files by downloading K**ppix to a CD and running that on my broken xp ...just downloaded it, ran it, and I was able to access all my folder/files that I didn't want to loose...**w I can use my recovery disks to get my computer running again..I would recommend this option to anyone with ** xp disk...it saved me from loosing important files that I needed...just thought I would share this with you since I k**w many pc's do NOT come with the windows disk these days....
Mar 02, 2008 | Casio QT-8000 Network Terminal
Problem loading win XP-SP2
Don;t know if this is the cause of u're errors, but it might be do to the motherboard chipset drivers (the lack of them in u're windows version). If so, u have to make a copy of u're windows cd with all u're motherboard drivers included, and try to install with that cd. The same problem appears to all new laptops that do not offer XP support and only Vista support . In order to do the new XP cd, u\ll need a little program that u'l find on internet..... (for example: n-lite)
Jan 18, 2008 | ASUS A8N-SLI Deluxe Motherboard
Downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
Aug 06, 2007 | Compaq Presario 1200XL104 Notebook
Computers & Internet Logo
316 people viewed this question
Alun Cox
David Payne
David Payne
