Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Husqvarna ranger 55 chainsaw starts but quits
I have a Husqvarna rancher 55. Cut several loads of wood this year until saw started to run erratically and then stop. Saw would start after choking, but then stop like not getting gas. Didn't matter if it was hot or cold. Eliminated possible problems, plug, fuel filter, tank vent, fuel mixture. Now saw has no spark. Determined the coil was bad after unplugging kill wire and no spark jumped from the plug to ground out on the motor. Replaced the coil. Checked the gap, checked the magnets in the flywheel, still no spark. What haven't I checked?? Why no spark? Should I check for continuity?
  • 4 more comments
  • drbrunk May 29, 2009
    I'm quite certain it doesn't have a spark. I have tried it with the plug in the wire - no spark. I tried with starting fluid - no fire. Held my file in the plug end while pulling the cord - no shock. I checked the resistance with a multimeter. Old coil has 5ohms of resistance, new one has 2.8 ohms. I would gather from this that old one was going bad? New coil came with a new plug wire.
    A little background that seems irrelevant, but I'm not an expert; while waiting for the new coil to arrive, I tried to remove the chain sprocket for lubrication by placing a screwdriver with string on it in the plug hole to lock the piston so that I could access the sprocket needle bearings. I gave up when it seemed l like I was going to break something. Could this have any bearing on the problem?
    Fly wheel seems secure and I don't believe I have sheared the pin binding it to the drive shaft.
    Any ideas?
  • drbrunk May 30, 2009
    I have checked the on-off switch. I disconnected it from the coil. It doesn't touch anything when the pull cord assembly is in place.
  • drbrunk Jun 01, 2009
    Thanks Jake 77. The fuel line was cracked exactly where you said yours was (where the line exits the tank). I replaced it with a clear line, so I can be sure this isn't the problem in the future. I got it to fire once or twice, but not actually run yet.
    Now problem seems to be that it is flooding. I've pulled the cord with the plug out to try to get rid of excess gas, but everytime I remove the plug it is soaking wet with gas. I even tried to adjust the idle screw, as I had adjusted it before I knew part of the problem was the gas line. This didn't help either.
  • Dean
    Dean May 11, 2010
    Worth checking the spark plug lead too. Could be damaged.
  • josh1111 May 11, 2010
    how sure are you id doesnt have spark? have you felt the spark or just tried to see it. most of the time you cannot see it in daylight that why i prefer to have someone pull it and hold a metal screwdriver between the plug and plug wire, this makes me 100% sure there is no spark. is the plug wire bad have you tested it for resistance?
  • Anonymous Mar 31, 2014
    after replacing spark plug and ignition coil there is intermitent and weak spark saw will not run
I too have a rancher 55 and had what sounds like the same problem this week. It would start fine but run for only a few seconds at a time. I took it all apart today and found the problem - a cracked fuel line. In the places where I could see the hose it looked fine, but it wasn't until I removed the fuel tank that I found the crack...right where it exits the tank and then goes thru the housing above it. You don't need to remove the tank to replace the hose but it is easier that way. You do have to push it thru a grommet at the top of the tank. I read some other posts about checking the tank vent to see that it's not plugged up. Mine was ok so I knew it had to be something else. The vent is in a hole about the size of a pencil and is recessed about an inch into the tank on the upper right side. Its partially covered by a plastic cap that's part of the vibration damper, which can be removed to gain access to the vent. The vent tube can then be pushed out from inside the tank with the use of long needle nose pliers, but be gentle. I just loosened it then pushed it out with a finger. I put it all back together with a new hose and its running like new again!
Posted on May 31, 2009
  • jake77 May 31, 2009
    By the way, you may not have a spark problem at all. I checked the spark and could never see it either, but yet when I put the plug back in it would fire up. I did like I've always done with lawn mowers to check for a spark...remove the plug, hold it against the cylinder head (plugged into the wire of course) and pull the starter. As long as I'm not in bright sunlight, I've always been able to see the spark if its working properly. But I was amazed that I couldn't see it on the saw.
  • 5 Answers
It doesn't sound like you've checked the on/off switch. Make sure its good. Also, make sure the ignition coil primary (small wire) isn't grounded (touching) to the saw frame.
Posted on May 30, 2009
445 HUSQVANA SAW QUITS
Sounds like fuel starvation, always start with simple things first, replace the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of leaking.
Jan 18, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Hi, my name is chris and i own a 460 rancher. just today the saw started to bog down when a load was added to it. seems to run at max rpm with no load however once touching the wood it will start to bog...
Hi Chris,
Check the air filter is clean and the choke plate is working ok.
Ensure the chain is sharp.
Check the chain isn't damaged and dragging in the guide bar.
A blocked muffler/silencer can cause loss of power.
Try screwing the "H" mixture adjustment screw in with the engine running at full power to reduce the richness of the mixture. Do this 1/4 turn at a time. Ensure you count the number of turns so you can get back to where you started.
Apr 28, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
I have a Rancher 55 18" with a new chain. Started
First thing you need to check is the cylinder.Take the spark plug ouy.use a flashlight and look down the hole towards the muffler side.If its scratched up afraid the motor is shot and will need to be rebuilt.If its not scratched up let me know on here.Then I will give you more things to check.
Mar 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Cutting with 455 rancher chain locked up took cover off ,replaced chain and put cover on still locked up
Husqvarna - IPL, 455 Rancher/ 460, 2006-02, Chain Saw (example - may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601076.pdf
See Detail A, pn 503 89 08-02. You can use a Crescent Wrench on one of the ears (left end) to reset it. With the cover positioned with pn 503 89 08-02 in the upper left rotate it CW until it nests, to reset it.
This works quite well:
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
You can download the IPL for you saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I will wager you will NEVER again remove the cover with the brake set. Me either! Good Luck. HTH
Lou
Feb 25, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Looking for proper h/l jet settings on my husqvarna 266 se chainsaw..or a manual i can download ...i found one...but it was in swedish
rule of thumb is 1 torn out from closed will get you started. then run at high speed and richen the H screw till you hear it just starting to bogg down every few seconds. Then let off the throttle and adjust the L screw till it runs smooth the richen it a quarter turn. Thats the old fashioned way I have been using for 40 years
Nov 18, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Loss of power; Rancher 55
HI. FRIST OFF THOSE SAWS ONLY WORK GOOD AT HIGH RPM.NOW I ALWAYS SET MY HIGH SPEED AT 3/4 TURN AND THE SAME FOR THE LOW. WHEN YOU START IT UP, FIND A PICE OF WOOD THAT IS A BIG PICE OF WOOD THAN YOU SHOULD BE ABLE TO SET IT UP. IF THAT DOSEN'T WORK GET BACK TO ME THERE ARE OTHER THINGS YOU CAN CHECK. THANKS JIMBO
Aug 11, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Sounds like it could be fuel starvation. I just had a case of exact same except mine finally worsened. Most likely and what I just encountered, its your fuel line. It's a quick and simple fix and you can do it yourself. Youtube has several videos showing you how to do it. Feel your tube, if it feels soft or spongy, it's probably got cracks or even a pin hole somewhere. It's $10 and as I've learned, one of the most common fixes when saws start cutting out at full throttle or under load. My dealer said he's been through 15 of them in the past 3 months.
May 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 350 quits under load
had the same problem the other day with my model 55 rancher found the pin missing that
holds the handle to the trigger mechanism once i found the pin put it back in the handle the unit works fine. the pin is about 1/8 X11/4 " long.
Apr 22, 2009 | Husqvarna Chain Saw 20" Bar
Bad Clutch??
Hi
Before other checking change the spring of the clutch(2).
best regards savumihai71
Feb 14, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
2,570 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
