Question about Canon imageRUNNER 210S Copier
GRAY STRIPES ON COPIES
I GOT GRAY STRIPES ON COPIES FROM CANON IMAGERUNNER 210S. I TRIED TO EMPTY THE TONER LEFTOVER BOX, AND CLEAN THE GRAY COLOR ROLLER. THE STRIPES ARE LESS DARK, BUT THEY ARE STILL THERE. PLEASE HELP
  • tsmai May 31, 2009
    You mean the scanning glass ?
    The scanning glass is clean, or you mean another glass?
    Do I have to replace the gray roller?
    Please advise. Thanks
  • 105 Answers
Clean the glass. it must have streaks
Posted on May 28, 2009
  • Jim Carlton
    Jim Carlton Jun 01, 2009
    I think your scanning glass may have scratches. You can clean the grey wheel with denatured alcohol or rubbing alcohol.
    Good luck, sorry for late reply, but my real job comes first.
    Jim
We have a imagerunner 210s. we just replaced the fuser unit and now when you try to copy, it copies the original but when it feeds through the exit door, it jams and when you open the door, the paper is...
please to see the claws. they are 5 claws which pluged on exit unit.
if you open the cover exit you will see them.
the shape like as a tigers claw. but more like as triangle.
they are move by spring, you try to moving. what are they work well?
problem usually cause
- the spring was loose or (you can plug or replace the spring)
- the claws have broken or (you replace a new)
- the claws dirty by crust toner. (you can clean up by your finger or your claw)
good luck.
May 22, 2011 | Canon imageRUNNER 210S Copier
I am getting a one-inch gray stripe at the top of each copy, and a half-inch stripe at the bottom of each. I think I've cleaned everything ... platen, narrow glass, rollers, etc. ... and it's lightened,...
there is no corona wire but a primary charging roller pls clean it if both ends of the roller looks rough or cracky try replacing it and clean transfer roller as well.
Jan 01, 2011 | Canon imageRUNNER 2200
The copies are very light. I have tried to adjust exposure, no change. I have already added toner. drum? fuser? Clean...what?
firstly clean the beneath the copyglass and clean the optics ( mirrors ), then try...
also try to darker the copy and see what happens, if its still light try to change the drum....
PS are you using the original Canon toner?
Nov 09, 2010 | Canon imageRUNNER 210S Copier
I have a canon imagerunner 210s recently bought already used. It was working ok but now copies are comming white, it does not print anything. could you please tell me what to change either toner or drum...
With the IR-200 one of the main problem is that the transfer roller falls out of place. It's a weak link, you will find that the transfer roller has poped out of the transfer unit. It is located on the transport unit. You can get to it from the front door and release the main lever for removing paper jams... The part are most likely all there,but you will need to put it back togather.... Good Luck
Oct 23, 2010 | Canon imageRUNNER 210S Copier
The printer copies turn out with a faint gray background through half of the copy. Its as if something is dirty and it printing the dirt.
it could be few things,
Its probably drum unit fault, probably the cleaner is worn out and doesnt clean drum surface enough.Remove the drum unit and see if there is "leftovers" on drum surface and if Yes change the drum unit.
If the copie isnt baked enough that means that the fixing roller is worn out and you need to change it.
If You are using replacment toner, not genuine from Canon, also it can cause problems like bacground, dots, spots,...
Hope that helps!
Sep 09, 2010 | Canon imageRUNNER 1023N Black and White...
Half looks great but the other half is gray scaled has been getting worse for about a month
1)So, your copie is half with good black color, and other half light, with possiblle white streaks?
IF YES: you need to clean the laser unit and replace the toner cylinder cleaning blade, also check the drum unit - if it got over 25000 copies change it too.
2)So, your copies are half good and half like no toner is fixated on paper?
If thats the case replace fixing roller and bushings, and check the press. roller bushings.
Feb 01, 2010 | Canon USA - COPIERS - ImageRUNNER 2010F...
Have you replaced the drum unit resently? When you had the drum unit out did you see the lines on the drum it self? If so, you need a new drum... If you did not see lines on it the problem may be coming from the fixing film, most of the time if the film is bad you can rub the toner off the page... Good Luck...
May 28, 2009 | Canon imageRUNNER 210S Copier
Photo copy comes out like tire marks are on it
Power the unit down. Let it cool for at least an hour. Remove toner carts, using a soft cloth and q-tip clean toner surfaces. follow warning stickers on unit. Examine cart/drum rollers for wear and baked on toner. Reassemble and clean platen glass and scan bed area with water or non-alcohol cleaner and soft cloth.
Jan 26, 2009 | Canon imageRUNNER 210S Copier
Copy Problem
this could be two things first, the transfer belt is slipping. It can be cleaned on the inside of the belt and the rubber drive roller. second, the laser units need to be timed, its not hard to do but a service tech will need to do both. it should be running great. the 3200 is a great box
Dec 06, 2007 | Canon imageRUNNER C3200 Color Printer
Canon imageRUNNER 210S Copier Logo
256 people viewed this question
old marine
old marine
