Question about Coby MP-C7085 MP3 Player
Jammed power button
MY BUTTON HAS JAMMED AND I CANT TURN IT ON
  • 30 Answers
Hi there! If you cant push it back try pushing it with a flat skrew driver, or try to bring it to the store from once you purchased and make sure you bring the receit.
Posted on May 28, 2009
Commander sunroof
only 2 possibles
1: no power , 12vdc to motor
2: motor bad. (got 12vdc there active)
3: or its jammed.
to tell if its jammed is easy , disconnect the motor drive
then turn the drive end by hand , cant move it? that means the panel
tracks are jammed and the motor can't move it.
so unjam it, by close examinations. of the guides etc.
the FSM has the full instructions on this, why not read the FSM
then ask questions that are not clear there. or?
May 02, 2014 | 2010 Jeep Commander
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
My Iphone4 wont turn on.(the power button is jammed been so for awhile).it always been in a otter box,almost 2 years old. and it was in my pocket and was working fine 1 minute pulled it out the next i
try putting it back on the charger & see if it turns on a friend of mine had a jammed lock button & when her phone died thats the only way she could turn it on. if it doesnt than theres most likely a battery problem. Also go in a very dark room & see if it works the backlight could be out on it
Feb 18, 2014 | Cell Phones
Carriage jam message...........comes on no matter what.........reset several times
Give a call to HP Tech support team they will try to resolve your issue. You can contact them (877-690-9305) Support For Hp Printer
Jun 21, 2011 | HP Photosmart C5280 Printer
I have several sheets of paper jammed in my printer and I can,t pull it out
Welcome to FixYa!
Don't try to pull out the jammed paper at the front panel of the printer. You might risk damaging your printer. Remove the jammed paper from the "Back Door" of the printer. The type of backdoor depends on what kind of HP printer you have. Below are 2 common backdoor of HP printers.
1. Press the Power button to turn on the printer.
2. While the printer is still on, disconnect the power cord from the rear of the printer.
3. Turn the printer so that the rear of it faces you.
4. Press in the tab on the left side of the rear door to release it. Then pull the door away from the printer to remove it.
5. Gently pull any jammed paper out of the rollers with your two hands.
6. Return back the back door. Gently push the door forward until it snaps into place.
7. Plug the power cord into the printer.
8. Turn the printer on again using the power button.
Note: Make sure to remove the jammed paper cautiously, any small pieces of paper left inside the printer might cause additional paper jam.
Some HP printers uses a latch to open the backdoor. Refer to the image below:
I hope that this will help you.
Thank you for using FixYa and keep me posted.
Jas247
Mar 09, 2011 | HP Office Equipment & Supplies
Paper jam
If you are experiencing paper jam problem with your printer, please follow these steps: 1. Remove any loose sheets of paper from the input tray and the output tray. 2. Press the Power button (c01602202.gif ) to turn off the product. 3. Disconnect the power cord from the rear of the product. 4. Unplug the power cord from the wall outlet. 5. Turn the product around so that you can access the rear side. 6. Push in the button on either side of the two-sided printing accessory (duplexer), and then remove the duplexer. 7. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them. 8. If you do not see jammed paper in the rear access area, push the buttons on the latch on the rear of the duplexer, and then lower the cover. 9. Remove any jammed paper from inside the duplexer. 10. Close the duplexer cover. 11. Gently push the duplexer into the product until it snaps firmly into place. Do not press the buttons on the end of the accessory while you reattach it. 12. Reconnect the power cord to the rear of the product. 13. Plug the power cord back into the wall outlet. 14. Press the Power button (c01602202.gif ) to turn on the product.
If you need any further assistance, please comment back.
Feb 13, 2011 | HP 8500 Premier All-In-One InkJet Printer
Jammed Insinkerator ISE55 Waste Disposal Unit
With a flashlight see if there's a spoon or fork jammed in there. Get a boomstick (or crowbar) and try to turn the spindle counter clockwise.
When its is loose, get the jammed stuff out, turn the disposer on. If there's no power, re-set the fuse-button on the bottom of disposer.
Jan 18, 2010 | Franke WD751B GPS Receiver
Says there is a paper jam
Open this puppy up and look for the paper jam.  Pull the jammed paper out and load up the paper again.  Push the power button to turn the thing off and then push the power button to turn on the thing.  This will clear the message.
Oct 29, 2009 | HP PSC 1315 All-In-One InkJet Printer
Catridges are jammed
You can keep the printer plugged in, and hold down the power button and cancel button until it releases.
Aug 17, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Paper jammed .....but no paper jammed
Sounds like this is a common problem with these printers. Hopefully, this is a malfunction of the printer that you can remedy.
I'm assuming that you have THOROUGHLY searched the printer for any evidence of paper and/or debris. Have you tried resetting the printer? If this issue is as simple as just needing to clear the error from the printer then a reset should work. (If you still have the manual, it should provide instructions on resetting the printer.) This is the best that I can provide on how to reset it:
  1. Turn the printer off.
  2. Hold the Resume button (red circle in the triangle), add a printer (click Power) an indicator light green.
  3. Hold the Power button and release the Resume button.
  4. NOT releasing the Power button, double click Resume and release BOTH BUTTONS (Power and Resume).
  5. Click Resume four times.
  6. Click Power to confirm the selected action (reset counter absorber). Click Power again to disable the printer.
Please rate this solution or let me know if this was any help.
Mar 27, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Coby MP-C7085 MP3 Player Logo
78 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
