Question about Intermatic Timer T12404R Pool & Spa Controls with One T104M201 and T104M
Pool timer not turning pump on
Pool timer motor is spinning when you look in it and the timer is keeping time but when it gets to the start pin it does not turn pump on and the time stops there..... it is an intermatic timer
  • 1,869 Answers
The timer motor brushes are worn out
Posted on May 28, 2009
Why when i just installed a new T104 timer yet seems wont turn on with pins
Are you sure that you put the pins on right? They have little projections on the bottom that turn the timer on/off as the cam moves through its 24 hour rotation. The little gear in the back is connected to the motor and because it is spinning that tells you that the motor is definitely good.
Sep 11, 2015 | Intermatic 220v T104p Swimming Pool Pump...
I have purchased a new pool pump motor complete unit its a onga ppp1100-02 since i have had it it has had new brushes in the motor i think they said it was fusion you can hear the motor load up but not...
It could be the capacitor is bad. The capacitor stores up a charge of electricity which it discharges to start the motor without it the motor cannot start against a load. If the capacitor is good the internal switch may be sticky or faulty.It is located under the back cover of the motor. It is a centrifugal switch that starts the motor on the capacitor and start windings and as the motor spins up to speed switches to the run windings. Check to see that it operates smoothly. Hope this helps.
Dec 31, 2013 | Intex Wet Set Water Filtration Filter Pump...
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
The pool timer goes on, the hayward 2 HP pool pump turns on and then causes the circut breaker to pop. After two, three resets, it starts to work. This problem started a week agao. The pump is 9 years old.
could have a bad run capacitor or a start capacitor . search your area for your local pool pump motor repair guy with free testing, 9 years old that motor needs to be rebuilt.. i charge 85.00 to rebuild a 2hpincludes a free shaft seal.. remember to prime the pump with water after a repair !! best of luck .. oh breakers become week after amount of time time .. and ask the repair guy if this is the right size pump for you pool.. 9 out of 10 times its way too big !.. jay longwood florida
Sep 08, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
Hi - My Intermatic T101P3 timer motor stops after it turns off the pool pump. I have one start and one stop time in a 24 hr period. I have to manually start the pump at the timer in the morning,...
Sounds like the clock leads are on the wrong posts, or at least the hot one is. If if was moved to the load side then manually starting the timer will also power up the clock motor. As soon as the clock trips the off timer, the pump and the clock motor are both off. Examine the clock leads to the wiring diagram inside the clock box cover to ensure they are connected correctly. I bet you'll find one of the wires is misplaced.
John
Aug 31, 2011 | Intermatic T101P3 Pool Timer IndoorOutdoor...
I have a dayton model 2e353a timer to turn my pool off & on. It's quit keeping time & allowed pool motor to run constantly
Replace defective timer with new one.
Did you include correct product number?
Dayton is owned by WW Grainger.
Grainger site does not show that timer number.
Internet search does not show that timer.
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+timer&op=search&Ntt=dayton+timer&N=0&sst=subset
Add a comment and describe timer in detail, and include photo posted on flickr, include number of pins or contact markings, voltage of control circuit, voltage of load circuit, and type of pump (1 or 2-speed) with HP rating for possible new timer recommendation.
Aug 16, 2011 | Amperite Dayton Solid State Timer On Delay...
My pumps won't go off when the timer says it should. It just keeps running. I have to throw the breaker to turn off the pumps.
Does the manual override turn Load ON-OFF? If manual override is broken or doesn't operate, it may be time to buy new timer mechanism and snap into existing box.
http://www.amazon.com/dp/240Volt-20
http://www.grainger.com/Grainger/INTERMATIC-24-125V-Hour-Dial-Timer
Do timer dials rotate as time passes? Do dials keep proper time? If not, you need new clock motor. Grainger sells clock motors and trippers:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Are the tripper pins still attached to the dial? If tripper pins are worn down, they need replacement.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 05, 2011 | Intermatic PF1202T - Pool-Spa Freeze...
Clock does not work to turn pool filter on and off. do I need a new timer mechanism or clock motor
Things to check:
1) Is yellow dial rotating? If not, then clock motor is probably bad. T-100 240V time clock motor sells for $16 at grainger.
Also timer may not be getting 240V so check manual override.
2) If clock motor is turning, but manual override never clicks on-and-off, then pins are probably worn out. Buy pins at grainger
3) Does manual override work? Does it click crisp? If manual override clicks crisp on-and-off, and pool filter turns on-and-off normally, then a) the circuit is getting 240V and b) the timer mechanism is ok ... so clock motor is probably bad.
4) If manual override snaps crisp but pool timer does not turn on, then then circuit breaker could be bad, wire is loose, motor has gone bad
Test for 240 across poles 1 and 2
... or timer contacts are worn out & you need new T-104
See back of mechanical timer
5) If manual override is loose or sluggish, then you need new T104. You can buy a T-104, T-104R, T-104M etc ... and the interior body will snap into old box.
Note: Do not buy T-101 or T-103 as these have 120V motor.
Sep 29, 2010 | Intermatic T104M 208-277Volt 40-amp Timer...
Timer for pool pump keeps time but will not turn on or shut off the motor. Off & on pins are tight.
MAKE SURE THE PINS DONT BOTH SAY OFF. IF YOU LOOK CLOSE AT THEM ITS STAMPED ON IT NEXT TO THE SCREW.. I THINK YA GOT 2 OFF SCREWS OR THE ON IS BROKE. I THINK HOMEDEPOTE SELLS THE ON-OF SCREWS KIT.. CHEAP .. TAKE THEM OFF IF ONE IS LONGER THAN THE OTHER THE CAM ON WITCH THEY HIT MIGHT BE BROKE. THIS IS VERY RARE !.. VOTE IF'N I WAS OF ANY HELP..JAY
Oct 28, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic Timer T12404R Pool & Spa Controls with One T104M201 and T104M Logo
889 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
