RCA Pearl TH1102 MP3 Player Logo
Posted on May 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My rca lyra keeps turning on and off and when i hit the play button it shuts off and turns it self back on It turns on and starts to play but will shut off or if you try to go to the next song it shuts off. I don't know what to do with this.
Geoff
Level 3:
  • Master 562 Answers
  • Posted on May 29, 2009
Geoff
Master
Level 3:
Answers
562
Questions
0
Helped
179164
Points
1681
How old is the Lyra, sounds like the battery isn't charging or is in need of replacement...
You could have a look here > http://www.rcaaudiovideo.com/product.aspx?product=410
1helpful
I have a mp3 rca lyra radio and mp3 player. It
Do you have the RCA LYRA PEARL, with the folding out usb plug? RCA has made bunch of different mp3 players and has reused the LYRA and the PEARL name. Mine has both names on it, and the firmware file below is for model numbers TC- or TH-1602 or 1604.
One time I replaced my battery and my unit would not go any further than the Pearl logo. So, I downloaded the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and followed all the troubleshooting instructions that popup when you start the program:
start the program,
remove the battery,
hold the play button while plugging into usb,
release the play button the the term "initalizing" replaces "searching",
check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
click the start button to replace the firmware.
After I did this, my pearl started normally, and my computer recognized it again.
1helpful
MY RCA LYRA MC5102A IS NOT WORKING RIGHT!
go to the thompson.com website and download the new software for your player..
Turning off
check to see if its locked on the back ,lock button could be stuck or locked'
Rca lyra rd1072A
You need to switch the lock off on your LYRA. It is located on the back of the device between the pictures of a key and the word "off".
Turning On but Does not play
I used to own this mp3 and have had it for many years and it has froze up a few times but not like you describe it.
I can answer 2 and 3
2. I dont know what DSP stands for but it optimizes the sound for the genre you select. I personally liked the Rock DSP because it raises the bass.
3. Mode changes the playback mode dice is the shuffle and the circle thingy is if you have like 1 or 2 songs on it and don't want to keep pressing play after its done it automatically keeps playing until the battery dies. I personally don't use the circle mode because if you accidentally leave it on in that mode it drains the battery because it doesn't stop playing.
Key lock shut down
On the back of the player there is a button to the right. Above the button it says Off and below it there is a picture of a key. Switch the button upwards to turn the lock thing off.
6answers
Rca lyra rd1076a mp3 player
change the battery, or send it back it may very well have a problem that Your warranty with RCA will probably cover.
My Rca Lyra Mp3 keeps shutting down by itself and what must i download to make it compadible with windows vista
Try updating the player's firmware, you can download it from the RCA Website (http://support.rcaaudiovideo.com/)
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
RCA Lyra RD 2762B
you need a new hard drive they are really hard to find
4helpful
3answers
My mp3 player wont turn on
I suggest you might need to clean up the cantacts of the buttery poles from corrosion or it could be they are broken or out of place
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
