Designing something that requires building a motherboard. The board must be able to work a small motor and also light the object. You should know I am not a computer techie. Thank you for your help. Twily
  • 1,869 Answers
Get a plcc interface card or, a plcc pc interface from honeywell motor controls
Posted on May 28, 2009
Importance of Robotics courses for students?
Robotics engineers are required to have a four year certification in designing. Despite the fact that the positions perform related tasks, designers perform obligations that are more perplexing and are relied upon to have a more noteworthy comprehension of automated frameworks and mechanical building. An robotics degree project gets ready understudies to work with different mechanical, electrical and programming frameworks. Projects join center scientific and material science courses with building labs that permit understudies to work with mechanical parts and apparatuses.
Visit Here:
Netratva Best Vocational Training Robotics Web Designing Courses
Oct 10, 2015 | Computers & Internet
Can't get DB75EN motherboard to show up on screen. Black screen(No signal on Startup)
Most likely problem is a video type mismatch. Your description makes it sound as though you understand the case build process well enough.
The motherboard you purchased has a DVI-D output. It requires a special cable. There is no adapter that will convert DVI-D to any DVI analog signal. There are some shady manufacturers that sell them (they look good but don't work), but unless you buy a cable that has a digital-to-analog converter inline, you will need a monitor with a DVI-D connection in order to see any video.
Aug 21, 2014 | Intel Computers & Internet
How to learn web designing via online?
There are so many website you can choose from online. Just google it by key in learning web design online, you will see many of them. www.learnwebdesignonline.com is one example
May 15, 2011 | Computers & Internet
K so like I have an old K7 PRO VER:1 Motherboard its an AMD and I want to add some ports to it its got some other numbers on it too like N1996 it also says MICRO-STAR in really small letters and it has 3...
I am unfamiliar with what you mean by ports?
But, you cannot add more slots to your motherboard. The black ones are called ISA slots and the oldest kind, i doubt you would be able to find cards for that slot anymore. The brown one at the top is the AGP slot and it can only be used for certain types of video cards. I don't believe these are sold anymore either, but you might be able to find a used one.
If you are looking at added more devices to you computer, you will probably have to use something that connects using USB.
May 04, 2011 | Computers & Internet
Create free uk website 100% free? any sites that will let me create a free website 100% free and with the option of paypal on my site to buy things, not pizco, not free webs or webs cant get them to work,...
nowadays the designing a site is easy , you can go for built in templates , the web designing companies which gives the templates to build a site quickly , you can get sign up features ,discussion boards etc for instance i got my web design here http://www.thewebpole.com/twp/domain-web... can get free hosting for each domain
Apr 23, 2011 | Computers & Internet
AOpen AX4BS motherboard front panel connections & power on.
That model motherboard does not support on/off control of the power supply. Refer to the output diagram on the power supply, and there should be pins in the connector (not used on your board) that may refer to the on/off control. Those pins should be tied together. Then the PC will turn on via the main power switch, and will require a manual turn off when the display says its ok.
Oct 24, 2009 | Acer AOpen AX4BS-V (91.89J11.001)...
Bios Utility Setup
Tell it(The BIOS set up screen) to load default settings. Start up CD driver first. Then  Save and exit. Now install Xp disk and turn computer back on. After windows loads . Run the install disk that came with *********** board.  If I missed something or is doesn't work exactly as I stated , write back and I wil assist you farther.
Feb 16, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
First Time Build
Be careful to note whether you have the power switch connector plugged into the correct place. Sometimes with the two rows of multiple pin connectors it is difficult to tell if you have plugged it into the right place.
make sure you have the main 20pin power connector AND the 4 pin standby connector both plugged into the mb. The 4 pin receptacle on the board is sometimes hard to see because it is close to the CPU.
Unplug all the case connectors going to the mobo and try this. Take a small metal object like a small screwdriver and short out the two "power" pins on the mobo. The motherboard should power up. If it does, try plugging the case wires in again, being careful to plug them in across exactly the pins you used to turn it on by shorting it. If it still doesn't work, it is probably a faulty power switch on the case
Sep 06, 2008 | Intel Motherboard
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
