Monitor goes to sleep without any output on screen
SOURCE: monitor wont stay on- blue light is on. but screen keeps going blank.
Have you tried the monitor on another computer? If so, and it works, the issue is with your graphics settings on your computer. LCD and plasma based monitors often come with a protection circuit that disables the monitor if the synch or refresh rate are beyond it's capabilities. this is to protect your monitor from damage.
Do not exceed your monitor's max resolution.
Resolution is determined the following way:
Width x Height @ Refresh Rate
For your model:
More detailed information about your monitor can be found HERE. If your monitor is still under warranty, and you find it to be faulty, you may be able to send it to the manufacturer for repairs.
SOURCE: Screen keeps going black
you may need to change the video output to output 1 in your pcs monitor settings - if you have 2 outputs from pc, swap cable over and select identify monitor. the default for the monitor should be 1( a huge 1 over the display appears)
SOURCE: Acer V223W monitor goes to sleep and doesn't awake
Go To Start > Programs > Accessories > System Tools > System Restore. Select "restore my computer to an earlier date". Look at the LIST of Restore points. Find the DATE when this "Security Update" was installed and Select the last date before it was installed and Follow the "Wizard" to Restore it to BEFORE the Update you think CHanged Things. Too many variables to figure out without seeing it to determine what was changed but that will correct the situation and you will not loose anything.
SOURCE: power on and monitor goes to sleep mode
You need to try it on another PC, alos verify if the VGA cable is good. If nothing change, then you need to open it up, first thing to look for are the capacitors in the power supply. Look for cpas with bulging top/seal, see example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
