Question about OEM Systems Car Audio & Video
OEM Premium Sound System 6 Disc CD Player installation location
1998 Ford Escort Wagon SE options included a Premium Sound System. The OEM ICP featured an integrated AM/FM/Cassette Player. The system also featured an OEM Amplifier located under the driver's seat and an OEM 6 Disc CD Player LOCATED WHERE ON THE WAGON? No OEM literature exsists showing the factory and/or dealer installation location on the wagon. Can someone help with picture(s) and/or illustration(s) and/or description of specific location? Many thanks!
  • 86 Answers
SOURCE: Fuel Filter
The fuel filter is located against the firewall on the driver's side.
Posted on Feb 07, 2009
DevilCaddy
SOURCE: when accelerating the car starts to dog out
Your fuel tank which should be located somewhere aroung the rear axle should have 2 lines coming off of it from the top and running along side of the drivers side frame. One for fuel is for demand and one for return. Follow those lines and you will come across the fuel filter which is an inline filter
It should look like this pretty much. Example image only.
To install make sure you have a drip pan because obviously fuel left in the lines will come out. You will also need a fuel line disconnect tool which looks like this. 24e4f23.jpg
All autozones or checker stores will have this little guy and it's only $6 bucks or so. It will wrap around the fuel line and compress the retainer clips on either side of the fuel filter to be able to remove it.
When installing the new filter pay attention to the arrow posted on the side of the filter this should match the flow of fuel towards the engine.
Posted on Mar 16, 2009
  • 11 Answers
SOURCE: where is the pcv valve in a 1997 ford escort wagon
If you look at your valve cover its at the back on the right, it comes up and then its an elbow, it comes over the top of the valve cover then down. the PCV valve is either the elbow or the piece in front of the valve cover after the elbow.
Posted on Jul 07, 2009
SOURCE: I have a 1990 Thunderbird SC with the premium JBL
Contact Paul at polyscroll@hotmail.com.
He refurbishes them.
Posted on Sep 11, 2009
catally733
  • 117 Answers
SOURCE: cd cartridge wont eject on car multichanger
check pwr to unit . fuse in box , ground on harness to unit
Posted on Nov 14, 2009
1998 2dr ford escort se 2.0 fuel pump relay
behind the carpeted panel in the rear of the car on the drivers side or whereever your fuel door is
Dec 27, 2011 | 1998 Ford Escort
Just wondering if my 1998 ford escort se sedan has abs brakes?? Thanks in advance.
In 1998 4 wheel ABS was optional, Mechanic, or Dealership can verify.
Sep 23, 2011 | 1998 Ford Escort
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
Sep 13, 2011 | 2000 Ford Taurus
I want to find the location of the fuel pump relay on a se ford escort 1998 wagon.
Fuel pump relays are typically located in the power distribution box under the hood or mounted on the Drivers side fender wall. The Fuel pump relay, AC relay and Starter Relay are all the same type and interchangeable so you can change them out between each other, like move the AC relay to the Fuel pump relay position and see if that resolves the problem.
Sep 02, 2011 | 1999 Ford Escort
Does the 2005 GX470 Lexus play mp3 files?
Audio & Entertainment Audio System Lexus Premium Sound System with Automatic Sound Levelizer (ASL) and in-dash, six-disc CD auto-changer Speakers 11 Audio System Mark Levinson® [3] Premium Audio System with Automatic Sound Levelizer (ASL) and six-disc DVD/CD auto-changer Optional
Speakers 14 Optional
Watts 240 @ 0.01% THD, 20-20,000Hz [21] Optional
MP3 Audio Input Plug MP3 audio input plug Rear Audio Rear-Seat Audio System (RSAS) Optional
Antenna In-glass antenna with FM-diversity system Satellite Radio XM® Satellite Radio capability [22] Optional
DVD Entertainment System Lexus DVD Rear-Seat Entertainment System (RSES) Optional
Wireless Headphones Included with DVD Rear-Seat Entertainment System (RSES) [23] Optional
http://www.lexus.com/cpo/model_library/GX/2007.html Wheen you click this link scroll to the bottom of the page. It will be under Audio & Entertainment.
Mar 14, 2010 | Sony MHC-GX470 Shelf System
Where is the Camshaft Position Sensor located on a
this car has but one bank, the cam sensor is under the intake manifiold on the drivers side.
Feb 25, 2010 | 1998 Ford Escort
What color wires connect on an aftermarket cd player?
hot at all times: blue/red
hot in acc or run: blue/black
ground: black
illumination: red/black + green
RF speaker: blue/white + orange
RR speaker: black/white + blue
LR speaker: black/red + red/blue
LF speaker: violet + pink
this is for factory am/fm stereo non premium sound
Mar 04, 2009 | 2001 Ford Escort ZX2
1998 ford escort sound
check speaker wires on check connections
Mar 04, 2009 | 1998 Ford Escort
Fuel Filter
Feb 07, 2009 | 1998 Ford Escort
1997 ford tarus radio
Sounds like the amplifier has died. Best bet is to try to replace with a used one. Repairs are expensive.
Sep 09, 2008 | 1997 Ford Taurus
Car Audio & Video Logo
147 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
miles
miles
SuperN0va
SuperN0va
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
