My 52" rear projection tv "gallery" model PF-52A70, was working perfectly till last week. I turned it off to have dinner and now it won't switch on, It turned on once and thats it. it does the usual thing with the red light on the front which dims to fire up, but it goes back to standby. It sounds like a capacitor is not switching in, I looked inside and there is no visible component damage. You can hear the tubes start to warm up then it turns off and makes the usual static sound. can you help, thanks Pat.
  • pgr6 Jun 16, 2009
    the television is work fine at the moment, I think the fault is the start up capacitors (2 small black). I removed the board again and moved the 2 capacitors and it seems to work fine, you can also blow hot air on these to test them or cool them to isolate the problem, that is what I've done to solve my fault.
    Novelist:
  • 151 Answers
Its the problem of power supply board failure.many users are facing  the same problem.as nothing seems to be burnt on the board as capacitors looks fine.the board gets internal short circuit in the tracks and this happens.the red light on the front dims to fire up but nothing happens. you can get the new board at  www.partstore.com thanks.keep updated.
Posted on May 28, 2009
Hello Pat
This sounds like either the lamp has blown and needs to be replaced, or the thermal fuse has failed and needs replacing. Best to get them checked in that order. It may be safer to allow a TV technician to do the replacements just in case there are high currents inside.
Hope this is of some help and that you get your TV working again soon!
Best regards
nLinked
Computer Support Services
Posted on Jun 09, 2009
I shut the tv off last night and now it won't turn
If total dead (no lights on blinking etc) follow power cord into the set and find and check the main fuse--in this set it usually is a glass 5 amp fuse.
Dec 19, 2012 | RCA P52926 52" Rear Projection Television
Does the RCA TV model D52W20 have a digital tuner? or will I need a cable box to watch TV? At our location they just switched the signal. we just had a tube TV with the cable line in the back and up till...
Greetings Pete - No, your display is what is called HDTV ready, meaning it needs a separate tuner AKA set top box.
You need to get the cable box, plug in the component video cables into your TV (usually provided) and plug in audio cables and you're viewing HDTV. See below:
Happy Viewing!
Regards,
Mikeywaf
May 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ihave a 52" Magnavox rear projection TV. Model no.
You need a convergence kit available at tvrepairkits.com
Jan 04, 2011 | Philips Televison & Video
I own a 52 inch rca projection tv and last week
Most likely the Horizontal output transistor has shorted. When it shorts it causes the power supply to chirp. This is a common problem with this series of TV. Have a shop check it out. It should not be real expensive.
Oct 16, 2009 | RCA P52926 52" Rear Projection Television
Rear Projection has perfect picture but no sound.
Open the tv backcover,check all the connections,and the soldering of the wire to the speackers.
Sep 25, 2009 | Philips 43P8341 43" Rear Projection...
My 52 in rear projectiontv would not turn on
UNPLUG UR TV FIRST go to the back of ur tv on the right there should be a panal that has three screws or more this is were the power switch board is . remove it and check that there's no black marking's on it if there is that the problem
email - bfd.pete@hotmail.co.uk
Jan 14, 2009 | RCA D52W19 52" Rear Projection Television
52'' GE Projection TV will not turn on
Called a service technician. Found bad board and wanted $437.00 I bought a new TV
Nov 12, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
52 in rca tv
does the light blink 3 times when you press power? Let me know exactly what happens when you press the power button. Please respond to this same post when replying.
Aug 07, 2008 | RCA D52W19 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
