Question about Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop
Computer will not boot
A problem with the hard drive has been detected. Consult the Troubleshooting section of your user's manual.
  • dennisofmena May 29, 2009
    No unusual sounds
  • 85 Answers
Does your pc make a different noise than usual when you turn it on? If it sounds like clicking (loud) then your hard drive has crashed. You will need to replace it.
Posted on May 28, 2009
Non system disk or disk error
Hi is the bios detecting the hard drive? Are you able to open the laptop and chek if the hard drive is correctly plugged into mother board
Feb 06, 2013 | HEWLETT-PACKARD 625 Notebook PC
Tip
Linux System not Booting: A Troubleshooting Session
<span>In a recent days in our lab I've got a with Linux file system. <span> </span>Our lab used Redhat Linux 5.3 Enterprise version. Redhat Linux is an Unix based Operating System and It based on Ext3 file system</span><br /> <span></span> <br /> <span><span>Problem of Linux:<span> The systen cannot access internet. It shows the license expiry error notification. Some</span></span><span>time it doesn't detect the hard drive. Some time the pc can detect hard drive but the Linux started with some errors of file system. Finally the file system of the OS getting crashed and can't boot. At GRUB loading stage it become restarted.</span></span><br /> <span><span></span></span> <br /> <span><span><span>Solution or Troubleshooting: </span><span>If I replace the hard drive cable It detect well and start OS also. Then the pc can detect hard drive but the Linux started with some errors of file system. Then I discovered that there is a problem with OS.<span> </span>Though formatting can solve the problem but that needs a backup of important data. This is time consuming and risky. So I thought to repair the file system</span>.</span></span><br /> <span><span><span></span></span></span> <br /> <span><span><span>At first I'm trying to login in single user mode and repair the file system. I have tried to login by pressing "s" beside kernel at startup in single user mode. But the system doesn't boot. Then I'm trying to repair the OS by RedHat Linux CD. I <span> </span>Insert the CD and select rescue mode by pressing "F5" key. Then I got the single user mode. After that I check all file system sequentially. </span></span></span><span><span><span>/etc /passwd, /etc/shadow, /etc/securetty, /etc/pam.d/login. Those file was wrong. I updated those file by correcting. Then I update the auth config file. After that I boot the system again. But now also it don't get start. Then I rescue the grub by grub-rescue and also update the kernel. After the total process I'm tried again to login from single user mode in root and It get logged. After that I reboot the system and tried to login. Finally it logged in successfully and run properly.<img src="alokerdas.jpg" /></span></span></span>
on Jan 15, 2011 | Computers & Internet
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
Moments ago was working fine...rebooted and now it says missing operating system. Help
its possible that the hard drive has partially disconnected.
Turn of your laptop, the remove the small plastic cover over the hard drive area. Remove the screws that mount the drive, remove the hard rrive and re-install in reverse. (searh Compa website for info, or consult your user manual)
Try to reboot your laptop.
If this doesn't work it can be one of 2 things:
a. a virus
b. a corrupted boot sector (or Master Boot Record aka the MBR)
Find a friendly computer geek friend..they will sort it out for you.
Feel free to add more info to here and I will give you some more advice.
Cheers,
Steve
Jun 26, 2010 | Compaq Presario M2000 Notebook
Hdd is not getting detected it is new hard disk the hdd is 160 Gb,cables are good solution to be not to open hard disk
u have installed the hdd properly
but not the bios..
open biios
press <del> or the key suggested by the computer when the computer boots.
u will enter bios...
now go to boot section
make first boot as the hdd shown in the list....
save the settings and reboot.
if it fails ..
unplug ur hdd. a and plug it again...
and follow the instruction again
Mar 11, 2010 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Computer freezes when I start it
Please make sure the boot device is correct from BIOS.
If correct please boot your system from Windows XP bootable CD and choose recovery option in Command Mode.
run the command
chkdsk /f C:
Check the result and let me know if any error comes.
Jul 30, 2009 | Computers & Internet
My computer is sayin non sysyem disk what does that mean
That means that either the system is corrupted or the hard disk is faulty.
You will need to reinstall the system using a recovery disk or a generic windows system disk.
You can purchase a full recovery disk from HP for about $20.
Apr 16, 2009 | Compaq Armada 3500 Notebook
Hard drive
Sounds like a bad hard drive. Back up all your data.
If your drive is making clicking sounds .. do it quickly or you will loose everything when the drive stop working altogether.
Mar 14, 2009 | Computers & Internet
ABOUT SOFWTARE INSTALLATION
Greetings,
Put the Installation CD in the CD-ROM Drive
Make sure that your computer is to boot 1st from CDROM (consult user guide)
Power on computer and follow on screen instructions.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 29, 2008 | Microsoft Computers & Internet
Hard drive message
Probably the hard-drive has gone bad.. First try a complete re-install of windows (you will lose all saved data on the hard-drive, so if you can, back up all important files first)..
If that doesn't work, you need to purchase a new hard-drive
Apr 03, 2008 | Gateway GT4022 PC Desktop
Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
