Question about Kenmore Dishwashers
My dishwasher won't turn on or drain water.
I checked the breaker and it is fine. The panel lights flash but nothing happens. Water is still in the bottom and won't drain. The dishwasher is a Kenmore model 587.1518 and it is 2 years old.
reg501
  • 413 Answers
SOURCE: Kenmore Dishwasher, no power
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
Posted on Jun 22, 2008
SOURCE: Kenmore 587 model dishwasher produces water but won't spray or move from bottom
top washer arm not turning
Posted on Sep 29, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
wheelshot
  • 102 Answers
SOURCE: dishwasher runs, water doesn't drain out
sounds to me that you may have some suds residue in the dishwasher that keeps it from draining completely. Get you some dishwasher cleaner which you can purchase at wal-mart or wherever you buy your detergent, and clean out your dishwasher. It is a inexpensive test. Alot less expensive than having a tech come to your house. Make sure that your drain hose is mounted higher that where it goes into the drain. This is also a common problem that I encounter in the field. Hope this helps. Let me know if I can help you futher.
Posted on Apr 04, 2009
  • 530 Answers
SOURCE: kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Posted on Jun 02, 2009
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Bosch dishwasher she43m06uc/48 constantly trying to drain. Cannot reset to end cycle.
Have you tried shutting off power to it from circuit breaker panel for about a minute and leave door open to dish washer . If that does not fix it the float Is stuck from grime build up . You can down load a maintenance manual online on how to access it and cleaning tips.
May 17, 2014 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Oct 02, 2012 | Dishwashers
My Miele dishwasher has water in the bottom of it and won't run
Check the impeller on the pump to make SURE it's turning freely. There could be a piece of debris wedged in there - like glass or a screw from a pot handle. If this is redundant, I apologize.
May 24, 2012 | Miele 24 in. Novotronic G851SC Plus...
The lights of my Viking dishwasher VDB200SS are flashing and do not stop even if I reset the unit by pressing start for more than 4 sec. The pump is running when I connect the unit to electric power for a...
Hello Jo, welcome to FixYa.
Based on your post, I suspect you mean the drain pump is running as is common for Asko built machines such as your Viking with this scenario/error. I have good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What this usually means is the control has indicated a overfill. All the indicators flashing is the error code for overfill/drain error.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump or a inlet water valve, so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit activates the pump-out non-stop
letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary. Good luck.
Regards,
Macmarkus :)
Oct 17, 2011 | Viking VDB200 Dishwasher
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
No power to Selections, Water Did Not Drain
When you remove the bottom panel cover, check the wiring connection inside the junction box on the right for a loose or shorted wire.
If that's ok, open up the console and check the continuity of the thermal fuse that's clipped to the control board. Chances are it needs to be replaced.
Mar 05, 2009 | Dishwashers
Kenmore altra wash dishwasher, no water
Check the water inlet solenoid and the float.
Jun 02, 2017 | Dishwashers
Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
May 30, 2008 | Asko 24 in. 1885 Built-in Dishwasher
Bosch dishwasher model #shu33A
your dirty water backed up into the washer (which it shouldn't do) and probably clogged something in there,..i would recommend getting it flushed out somehow, not sure how,.....next time, your washer drain hose should go up under the sink as high as possible and then back down to drain,....this settup makes it hard for drain water to go back into washer,....it's instructed in any dishwasher manual
Mar 06, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Dishwashers Logo
66 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
