Question about RCA R52WH73 Projection Television
Hourglass shaped picture
Multicolored words and doubled vision picture
    Genius:
  • 1,030 Answers
This sounds like the common fl231 i sugguest you read the fl231 fuse problem under the tips and tricks section of this website. this is a simple very inexpensive repair
Posted on Jun 04, 2009
How do I get the double vision out of my tv
double vision? is this multicolored. red green blue? is the picture bowed. Have you tried going to setup in customer menu and adjusting convergence, Both manual and autoconvergence.
Oct 22, 2010 | RCA HD52W56 52" Rear Projection HDTV
Red lines, blurry picture
try this link. It fixed my sony.
www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 29, 2009 | Sony KP-51HW40 51" Rear Projection...
Double vision..
Adjust the convergence in the menu. If it will not adjust then solder connections on convergence ics or ics themselves need replaced.
Apr 26, 2009 | Televison & Video
Picture is smaller, has hourglass shape, no sound
Took back off, removed control board and inspected for bad solder joints. found no obvious problem. Cleaned and reinstalled. Working ok now. I'm crossing my fingers.
Jan 27, 2009 | Philips Magnavox TS3260C 32" TV
Hourglass shaped picture on rear projection Hitachi 48 inch older
you will need to take the TV and have them diagnosed it for you.
Dec 05, 2008 | Sprint Hitachi P300 Cellular Phone
Vertical hold
If the picture is in an hourglass shape this has nothing to do with vertical hold. Besides, on all these sets, the hold and parameters are all uPC controled through a firmware routine that is burned in to an EPROM.
It is obvious that there is a failed component somewhere because of the hour glass shape. The area of failure is most likely in the pin amp section. If the hourglass is from the sides, it would be horizontal pin. If it is top and bottom, the fault is in the vertical pin section.
A common cause is from a capacitor that has failed in the mentioned area. Sometimes it can be an IC or other type of component in the pin amp area, but not as often as failed capacitors.
You can take the set in to service the fault. I don't think you can fix this yourself unless you are trained in TV service and have the experience and setup to troubleshoot for the bad parts, and do this type of service.
Jerry G.
Apr 19, 2008 | Panasonic CT-32HX40 32" TV
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Help with my double vision
What model is your tv? Panasonics have a 'self-alignment' system in the menu, or a manual alignment that the menu will actually walk you through. Other System's will be able to do that also, such as Hitachi.
Aug 24, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Hourglass Shape
Yes check for fluid leakage and see if the crt's are leaking fluid down on board. if so you have to change some caps any that got wet. If not wet at all then something that was fix maybe has a solder bridge on it look carefully and see if anything out of place
Oct 30, 2006 | Philips 60PP9202 60" Rear Projection...
RCA R52WH73 Projection Television Logo
171 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
