Question about Freezers
Compressor starts then stops after 5 seconds
Hi my old electrolux freezer stopped working, the compressor starts and runs for about 5 seconds, then shuts down, it tries again after a short time but does ther same, its a model tf 1040, if its the starter relay are they still available Regards
  • steve
    steve May 11, 2010
    Probably a bad start relay. Change it out. If it still fails after that. Bad compressor.
    Director Badge:
    Uploaded 100 video answers.
  • Freezers Master
  • 489 Answers
Installed hard start Kit for this little freezer. No help. Needs new compressor.
Posted on Nov 26, 2015
  • 56 Answers
Yes you can order what they call a 3n1 it replaces the relay on your compressor but no guarantee it will work when installed as you could have locked rotor in compressor. part # rco-410 call for parts 877-262-1479 but is a non refundable part.
Posted on May 30, 2009
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
My 2yr old electrolux freezer just died. The food were defrosted and I think the compressor stopped working, I shut off and restarted the freezer but nothing happens. The light is on just the motor not...
Thermostat is most common, the next is the starter on the compressor, or the (if it has one) defrost timer has failed, I can guide you to see if the timer has failed, first of all, pull the unit away from the wall and gain access to where the compressor is located, you may have to lay on the floor to get a good view, look for a small box located on the cabinet in the compressor recess, if you see this box, you will notice a small circular dial within this box, get a suitable object and turn this dial clockwise, if this is the problem, your freezer will magically burst into life and you will need to replace this timer or the internal thermo switch, if it does nothing or you cant locate the box, suggest you start with the thermostat and work down, if you have no luck, give me a call on 08 9523 0552. Russ
Feb 27, 2011 | Electrolux Freezers
My upright freezer has stopped working. compressor cuts in every now and then, but cuts straight out after running for about 5 seconds.
your compressor is busted due to low chARGE OF OIL in the compressor or meybe the internal overload of the compressor collaps you must replace your compressor with the same s/n num..and size...
Aug 11, 2010 | Freezers
The motor run for about 5 second and stop, it keepe doing that since this morning. what should I do?
You probably have a freon leak and the compressor is cutting out on low pressure.... then it stops... the pressure builds and it starts again... it will kill it's self doing that...get it serviced right a way...
heatman101
Aug 07, 2010 | Beverage-Air 23.1 cu. ft. / 654 liter...
Hi there. I have Electrolux freezer EUU 6174. The problem is that the compressor is switching on and off for 5 seconds and the temperature is to hight. I can't store any food in the freezer. can u help me?
your problem is likely the starting capacitor .. that is a metalic part (about the size of a fist) that is mounted on the compressor or near it .. it will have wires going to the compressor .. the capacitors are not very expensive and usually easy to change but make sure the unit is unplugged .. you can either write the numbers down off the capacitor or remove it and take it with you to a parts place to get a match ... take a photo or draw a diagram so you know where the wires go .(they usually just plug in) . .. you can order one from electrolux (might be higher price) .. dont allow the unit to continue running with the bad starting cap since the compressor can be damaged eventually ... if you call a repairman .. then make sure you tell him its a bad starting cap so he can bring one wiith him and avoild a second trip .. give him the model number and numbers off the capacitor if you can ... often the capacitor is actually two capacitors in one can ... one is for the compressor and the other is hooked up to the fan ... in that case replacing one would also replace the other ..
Dec 23, 2009 | Electrolux 3.53 cu. ft. / 100 liter...
The compressor works for a few seconds but then stops. The freezer is over temperature.
Check the condenser fan motor (next to compressor) make sure it is running. Next change relay (inside black box) on compressor.
Apr 27, 2009 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Apr 22, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
Kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Sep 25, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
1,536 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
