Displays the follow message "strike F1 to continue, F2 to run the setup utility" i should select F12 to enter in "Boot menu and then, select option "Boot to utility partition" then the computer start load Windows normally, please tell me what i should to do, to starts the computer automatically... as the beginnig...
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
I have Dimension 5150 the is when I starts it msg come out :Strike F1 to continue, F2 to run the set up utility
once I strike F1 every thing going OK
but I want to get rid of this annoying msg
please help
HI, i have the same problem with my dell dimention 2400, whenever i try to boot from cd , msg come out : Strike the F1 to continur, F2 to run the set up utility . F2 takes me to the BIOS , i can see my HD. pc work normal if i start to boot from HD.
the only thing i did : i tried to add a used second HD to my pc unfortunately did work , it would recognize it but wont open (space use 0 , free space 0 ). so i removed the second HD , now i have the error that i mentioned earlier () strike F1...) please any help
Dear maisie h,
I reset the bios already and not helps, and also, bios don't display HD as boot choice , that's why i can choose it.
The model is DELL DIMMESION 2400.
HI ANY NEW SOLUTIONS AVAILABLE....
no, i don't hace any cd, because i bought it used. i mean i was the second owner.
Sounds like your operating system is corrupt. Do you have any of your cd's that came with the computer?
Reset the defaults in the BIOS and see if that helps.
I had this problem.... It was looking at all hard drive options.... All were set to auto in bios setup... When I turned to off choice except for the one hard drive it found, the F1 and F2 options went away.
