Sub-Zero 642
Problem for Sub-Zero 642
642s Temp Setting Does Not Work
By upallnight on May 28, 2009
I cannot set the temperature setting both on the fridge and freezer on the control panel of a 642/S. The control panel lights up the when does not show the temp. Is there a reset button? I can achieve a cold temoerature, but my refrig runs constantly. If I set it for 40 or 38 the refrig will sometime get down to 26. Both thermistors in the refrigerator were replaced. Do anyone know if I need to replace the control board?
Comments:
Sep 02, 2009
- had the service come and look at the sub zero. Both service said that there was a leak in the evaporator coil. First service wanted $2500.00 to replace the coil and compressor. Second service tested the compressor and said that it was still good and to replace the coil will be $588.00. Sub zero parts was used for the repair. Guess which one we went with?
Solution #1
posted on Aug 05, 2009
Not Rated)
halftank123
Rank: Guru
Rating: 87%, 28 votes
Possibly, but check your condensor before calling for service.
Was this helpful?
Yes
No
Popular Solutions for Sub-Zero 642
Questions and Unsolved Problems for Sub-Zero 642
Do you recommend Sub-Zero 642?
Answer
Answer
Whar size allen wrench do you need to tighten the handle on a sub zero 642 fridge?
Answer
How high do the ceilings have to be to install a sub 642
Answer
Black pan below refrig is filling up and overflowing with water; what should I do to minimize the... (More)
Answer
ice maker is not working. I cleaned out ice and put back but now it won't make ice .
Answer
the refrigerator is not working. the temperature is at 60 degrees even though I have the temperature... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sub-Zero 642:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
