Question about Olympus FE-340 Digital Camera
Olympus xd card formatting problems.
I have an olympus 2g xd card. when i format it in camera and then take photos , i can't upload them to computer thru card reader. i get a message from the computer telling me that the card is not formatted.if i format in computer then the camera (olympus e-500) tells me it's not formatted.i've been getting around the problem by copying the xd images to the cf card in camera.this is a nuicance though, so i'm wondering why won't my computer not recognize the camera formatted xd as formatted. this happens with all my xd cards so i know its not the cards.
  • davidhodges May 28, 2009
    i just tried the xd card in another card reader and computer and it had no problem. i guess the problem is with the computer or card reader.
  • 256 Answers
If you like the camera and XD cards then I would use the USB cable to download the photos from the camera. When you plug the USB cale into the camera and then into the computer, the computer should recognize the camera and set it up as another disk drive. Copy or move the pictures from the card to your Photo location. Use the "Safely Remove Hardware" icon in the system tray to disconnect the camera and your done. The camera can format the XD card and the computer can read it through the camera.
Posted on May 28, 2009
  • John Moore May 29, 2009
    Most of those little cards are fragile. I leave mine in my camera and hook up my camera,mI have killed 3 SD cards gently inserting and removing from computers and camera. Glad you have found out what is wrong though.
Format-less
put it back in the computer and try to format it there.
Jun 14, 2009 | Olympus Camedia C-350 Digital Camera
Formatting error on my olympus fe-340
never format the card from the computer... format using the camera.. use data recovery software to retrieve pictures if you have not formatted it... also make sure to "safely remove hardware" before actually unplugging the camera from the computer
Apr 06, 2009 | Olympus FE-340 Digital Camera
XD CARD Terminal
hi i have the same problem at the moment
i was wondering if anyone has found a solution yet to fix it without losing the photos. your help would be greatly appreciated, thanks
Jul 11, 2008 | Olympus FE-290 Digital Camera
Olympus 2G xd M card with pictures - error message "clean card" or format
Just had the same issue today. The Olympus Helpdesk told me that the fact I had printed one of the picture from the Xd card in directly inserting the card in the printer slot for Xd created the problem....
The guy from the Helpdesk strongly recommended to transfer the pictures from the camera to the computer exclusively using the USB cable of the camera.
In the end I have saved all my 505 pictures in using the Smart Recovery from PC Inspector but why the hell this problem only happens with Xd cards?
Apr 09, 2008 | Olympus Camedia C-350 Digital Camera
Screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
Mar 07, 2008 | Fuji FinePix A330 Digital Camera
No Image
Please read these/the 2 posts that I posted prior for a similar XD mem card problem, as I firmly believe you are "formatting" your mem card improperly using your home computer instead of "formatting" the card on your camera.
Also the XD type card & size are very important also!!
What you will have to do is read and download the photos you have on that XD card using the same "card reader" you used before and then properly "re-format" that card in your "CAMERA ONLY". This should solve your XD card problems.
PRIOR POSTS:
Kristina,
Not knowing what model Olympus camera you have, or how old it is - your new memory card "format" problem is one of 3 possibilities.
1st - If you have an older Olympus camera more then 4-5 years old the newer M & H series type cards over 256mb will probably not work in your older camera, as by the camera's internal firmware chip design of the camera itself. Some cameras were upgradeable some weren't as to the internal firmware chip as well as available software drivers depending on which computer OS system you were using ie: (WIN98SE, WIN2000, etc). Has to do with the memory card read/write chip speed as well, and also has to do with the physical storage size of the card itself. Some digital cameras were MAXED OUT at 512mb cards, some as low as 256mb. A 2gb card simple won't work in that/your camera in that case.
If you read the camera's user manual it will possibly tell you this, or else go online to www.olympusamerica.com and use this link:
View which cameras are compatible
Select camera model series and scroll down the model # and research the max card size & type you can use (3 basic XD card speed types available - regular XD - M type - H type).
If you are using the wrong type & size card you will need to return that card (if you can) and get the right XD size & type for your camera.
2nd - You should always FORMAT (same as ERASE ALL and FORMAT modes on most Olympus cameras) the new card, or any XD card for that matter in your camera itself. NOT THE HOME COMPUTER!!! The 2 format procedures are not the same!!
If you are re-shooting (re-using) the same XD card over and over again and then downloading the JPEG pix directly to the computer using a USB interface cable there usually is no need to re-format the card again as long as the XD card stays the camera and is not downloaded into a home computer via a "card reader". If you do the latter "card reader" then I would advise doing a card re-format in the camera again just to be safe!!
And lastly - If your home computer recognizes the XD card via a good "card reader" (do not FORMAT the XD card here btw, as you are just checking the card out to see it is GOOD is all), but the camera will not then that is a good sign your camera is OK, but it's just the wrong type & size XD card.
Hope this helps solve your camera XD problem not knowing which model you have.
Best regards,
Frank
AND:
Follow up to previous post:
I didn't have the time to access the exact link below to check on your specific 2004 model year camera because I missed the Fuji camera model part, as I'm brand new to this site - so please forgive my previous oversight here.
I was right though in my initial posted assumption that you bought the wrong XD memory card based on your Fuji FinePix A330 Digital Camera - as to it's older model year - in that your camera is limited to a 512mb memory card.
Make sure you buy the 512mb standard card if you still can find them. Otherwise check with Fuji Corp to make sure the M type card (faster read/write chip) will work in your specific model. The M type cards work just fine in my Olympus C-740 even though it was told to me they wouldn't work at all, but each digital camera is slightly different as to it's internal firmware (BIOS) chip.
See the following camera info for your specific model at the link below under Storage Media:
Steves Digicams - Fujifilm FinePix A330 - User Review
I hope this now clears up any prior confusion from the previous post.
Best regards,
Frank
Feb 06, 2008 | Fuji FinePix A330 Digital Camera
Not Formating Olympus Xd Picture Card H 512MB
very strange indeed better take the camera and the xd card to your supplier and see what is wrong .. i gues you have not pushed the card the wrong way?? or put the little white tab downwards ( than it is locked against accidentaly formatting )
it's the only thing i can come up with or remove the xd card put a few photo's on internal memmory than connect cam to pc > upload the pictures > then set the jog dial to setup > reset the camera and try again ,
Jan 19, 2008 | Olympus FE-180 Digital Camera
XD card Error
Try formating the card in the Camera twice. or Download PCinspector from www.convar.com Install this program and run the recovery program with the card in the media slot. Then back to camera and format, Come back
May 21, 2007 | Olympus Camedia C-350 Digital Camera
Olympus FE-340 Digital Camera Logo
428 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
