No audio output device is installed, how do I put it in?? MAG monitor, Compace tower..
How do I get sound with my MAG monitor and Compac tower??
    Problem Solver:
  • 9 Answers
Depends on what operating system you are using. If you are using Windows Xp and above. You can try going into add remove hardware. Try adding a new hardware from list. When you can try reinstalling the windows audio driver. This has worked for me numerous times. Try this step
My computer
-Control panel ( use classic veiw)
-- Add Hardware
--- Click Yes
---- Scroll down to the bottom of the list and select add a new hardware device
----- install from a list 2nd option
------ click on sound video and game controllers
------- Try the Aztech systems and use the first option on the right hand window.
then click next until you are able to install it. It should work after that.
Best of Luck
Posted on May 28, 2009
No sound from MAG 780
Dumb question, but do you have the audio cable hooked up from the monitor to an audio output on your computer, volume up, mute turned off.
Jan 27, 2013 | Mag Innovision LT Computers & Internet
I have a MAG Innovision Model 468 LCD Monitor and a Compaq computer, how can I get the monitor speakers to work?
There should be a wire to connect between the speaker output of your soundcard (usually the green connector) to the monitor's speaker input. It should be a "mini" plug, 3.5mm diameter. Make sure your speakers are not muted in the audio/sound controls on the computer.
Aug 24, 2011 | Computers & Internet
No sound coming from monitor. Am using Vista and HP pavilion computer. Have inserted audio cord into audio hole on monitor, but not sure where to put other end into hard drive. Have tried every hole....
Check for the green slot which is for audio output. If this doesnt help go to device manager to see if the sound card has been installed properly.
Nov 21, 2009 | Computers & Internet
Monitor only power's on NO sound and No Picture
check your cable to speaker of your monitor and to the audio output of your pc.
May 20, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
I've added a new graphics card and now get no sound.
I SUGGEST YOU READ A MAGAZINE CALLED CPU [COMPUTER POWER USERS]
FROM 11/2008 TO PRESENT ISSUES
ROD
Mar 12, 2009 | Computers & Internet
No audio output installed in my laptop
Go to the website Dell/Compac/Apple and look for updated drivers for your laptop and install them.
Jan 29, 2009 | HP Compaq Presario V5000Z Notebook
I can access sound output but not input
i have a compac presario c700 install sound driver
Nov 06, 2008 | Compaq Audio card Sound Card
Need to over-ride built-in speakers so desktop speakers work. Ever since I hooked up my Compac W17q monitor, the built-in speakers have taken over, but I want my desktop speakers for sound instead. How can...
Assuming your using a Windows operating system, you need to got to the sound settings and set your computers soundcard as the preferred output device. (Its under Control Panel > Sounds and Audio Devices in XP)
Aug 26, 2008 | Compaq 17" Flat Screen CRT Monitor
No sound out of monitor speakers
Is there actually any unknown devices in the device`manager?
Are your monitor speakers USB or do they plug into the audio out jack of your sound card or motherboard???
If they plug into the sound jack, then test the sound output with a pair of headphones.
Hope this helps you narrow it down. Please reply back if you need further help
Dec 30, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Oct 17, 2007 | Gateway FPD2275W LCD Monitor
85 people viewed this question
 Grubhead
Grubhead
