Question about Westinghouse SK-26H590D Television
No picture or sound
Blue light shines in dvd player, but tv has no picture or soundeither in dvd mode or sat. mode
    Problem Solver:
  • 9 Answers
Did you double check your connections with your AV cables. Otherwise you may want to try a new cable. Still make sure all connections are tight and secure and plugged into the right ports. If this doesn't work I would suggest call customer service for your DVD player.
Posted on May 28, 2009
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
Lost sound through tv/sat mode
Try unplugging all of the equipment for 30 minute to an hour, and see if this fixes it, otherwise, it sounds like the flickering power may have caused a surge in the circuitry of the equipment, causing it to short circuit the digital tuner in the TV.
Feb 23, 2008 | Pioneer VSX-D498 Receiver
My apex at2402has a blue screen
your' TV is in VIDEO mode... connect your cable or sat. or DVD player or cable box etc. to TV using the VIDEO jacks>>>>red , white , and Yellow wires....picture should be on TV now.
other ways to get a picture also....changing TV from VIDEO mode TO TUNER mode...etc
May 19, 2010 | Apex Digital AT2402 24" TV
I recently purchased a new Samsung Blue Ray player. My previous Sony DVD player used the blue,green, red cords plugged into DVD imput, and I used Coaxial for sound. The Blue Ray only uses HDMI, which the...
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
Dec 06, 2009 | Sony STR-DG500 Receiver
I have sound but no picture on my dvd player.. can
can you check the video jack,, and also the setting in tv tuner,, make it changes, to tv mode,, like vhf, uhf other things, in tv mode settings
Sep 29, 2009 | Philips DVD724 DVD Player
Toshiba dvd when plugged to componet to tv picture balck and white... The picture is fine when plugged to composite or s-video... Component from sat box plugged to tv works fine too..
Sounds like either the cables you are using are bad or the component out on the dvd player is bad. Try using a different set of cables and make sure there are no loose connections on the dvd player
Aug 21, 2009 | Televison & Video
Bad DVD picture
please reset the factory seetings in uer dvd player, throgh menu button on uer remote. Firstly open uer tray and after take rhe menu and select factory reset, and reset it,
Mar 02, 2009 | Philips DVP5140 DVD Player
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
TV has picture but no sound
Manufacturer and model number of TV would be helpful for maximum assistance.
What type of cable is connecting your sat box/cable box/dvd player/etc to your TV?
If it is via a red/green/blue cable, make sure you also have an additional red and white audio cable connected, and select YPbPr (or component audio) in your TV's menu
If it is via an HDMI cable, go to your tv manufacturer's website and get a firmware upgrade for your TV (if TV has a USB port).
Apr 07, 2008 | Televison & Video
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Televison & Video Logo
193 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
