Home | Trendware | TRENDnet TE100-P1U Print Server | Cannot add printer usi...
Trendware TRENDnet TE100-P1U Print Server
Problem for Trendware TRENDnet TE100-P1U Print Server
Cannot add printer using TE100-P1U from Dell Laptop (Vista)
By rplattsmier on May 28, 2009
The utilities that came with the print server install OK, but get an error when attempting to connect to the print server. Same issue - driver loads & finds print server (TE100-P1U) fine, sets IP address (& I can ping p/s ok) but Add Printer in Vista reports "Windows cannot connect to the printer. Make sure that you have typed the name correctly, and that the printer is connected to the network." then returns to the Add Printer window, listing U1 on PS-xxxxxx \\ps-xxxxxx\U1 as (only) network printer to select. Running Vista Home Premium sp1. The PC I'm doing the setup from is connected wireless to a Linksys wireless router; printer is hard-wired to 100Bt port on this router. Ideas?
Popular Solutions for Trendware TRENDnet TE100-P1U
Questions and Unsolved Problems for Trendware TRENDnet TE100-P1U
Do you recommend Trendware TRENDnet TE100-P1U Print Server?
Answer
Answer
I've connected my trendnet on a LAN via a switch. The LED light is on on the trendnet and it's... (More)
Answer
I have the same problem. My laserjet 1018 appears offline in the trendnet TE100-P1U and... (More)
Answer
When I connect HP deskjet models 3520 or 3650 to the unit's USB port, power up the printer, and then... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Trendware TRENDnet TE100-P1U...:
Top Print Server Experts
Rank: Guru Guru
Solutions: 3258
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Print Server Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
