Question about Linksys Computers & Internet
Linksys PPS1UW print server problem
I just got a Linksys PPS1UW 1-port USB print server. It is connected to a Linksys BEFSR41 DSL router. I have two HP printers:  a brand-new OfficeJet 6100 ("all-in-one":  printer/scanner/fax/copier), and a much older DeskJet 970 Cse.  The intent of the print server is to share the OfficeJet 6100 between two computers (Windows XP Pro and Windows ME), and retire the old DeskJet. The print server will not communicate with the new OfficeJet 6100.  It will communicate with the old DeskJet, using the same USB cable to the printer and the same ethernet cable to the router. The OfficeJet 6100 works correctly when attached via USB as a local printer on the XP machine (I haven't tried it on the ME machine yet). Any ideas? Thanks in advance. my linksys pps1uw printserver,isn´t compatible with samsung scx-4521-f (samsung scx-4x21 series)i need solutions, please help me. best regards salvador gonzalez
I have a linksys router. model number befsr41 v. 3. i have a acer computer and some reason it wont recognize the network, calling it unidentified network, and internet does not work.. what do i do
The first thing is that the router model number you have is not a wireless router.
Now if you are connecting the computer to the router with the Ethernet cable then check the port light on the router. If you connect the computer to the port number 2 then port 2 light should lit up on the router.
Now check the IP address on the computer. If you are not getting proper IP address then check the DHCP server on the router is enabled.
If that is enabled and still not getting the IP address then assign a static IP address on the computer.
Click Here for more information about router and network
Feb 23, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How to connect devices to 3-way video switch box
Normally on a 3-way video switch box, there should be 4 ports.
1 ports connects the monitor
3 ports connect the 3 computers video output
Mar 19, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Im trying to hook up my xbox and get on the internet by using a linksys
Physically connect the XBox to one of the LAN connection of the router or be connected wirelessly.
If unable to connect to the Internet open these ports using the router under virtual server or port forwarding:
TCP 80, 3074 and 53
UDP 88, 3074 and 53
Note: Also the IP address of the XBox should be open to the section.
Mar 08, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Opening Port 123 on my Linksys BEFSR41 Router
Hi:
It turns out I didn't need to open port 123 on my router to get SymmTime to work.
Thanks for the efforts
Brad McMillan
Dec 16, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
2 0f 4 ports do not work
It sounds as though the ports on the cable/dsl router as bad. There really isn't anything you can do. It just happens. The typical shelf life of those routers is about 3-4 years. You could go out and buy another one or if you just need more ports go out and buy a little 5 port switch and plug it into one of the working ports and your comptuers into the 5 port switch.
MO
Jul 12, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys router limits speed to 5 meg.
Try to access the router's setup page and change the MTU settings. The default address for the Befsr41 is 192.168.1.1. Here are instructions:
1) Use a computer wired to the router.
2) Launch a browser and type in 192.168.1.1, leave the username blank and the password is admin or the password you have set when you first configured the router.
3) Click on the Advanced tab then click on the Filters tab. On the bottom part you have MTU.
4) Enable that option and set MTU to 1500, 1400, 1300 (for cable ISP connection) and 1492 (for DSL connection) and check if it will work.
4) If that does not work, you can try upgrading the firmware of your router.
Apr 29, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
183 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
