Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Burners not lighting off pilot
Burners will not light from pilot. "SPK" stays on digital read out but burners do not ignite. Help!!! I get an intermittent buzzing sound from the pilot area as if the the electronic ignition is trying to ignite?
    Problem Solver:
  • 4 Answers
Sorry, no solution, but I have a similar problem, so if you could let me know how things get resolved, I'd greatly appreciate it.
On mine (a 2100 model R405A), this is especially likely to happen during or after wet weather. Not sure if the ignitor is the problem. After power on, I hear the ignotor clicking for a bit and often then I hear an odd sound and then the clicking stops. My LCD is totally gone (a whole separate issue), so I can't tell you what message is there. But, usually after a good period of drying out, the unit fires up ok.
Seems to be getting progressively more prone to this as it ages (installed 2002).
If you have any more info, please let me know @ sroche@tellink.net or here
Thanks,
_Steve
Posted on Jun 22, 2009
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
What part do i need when plt code comes display ?
spk I think means spark for ignition and plt means pilot so i assume the heater tried to light but the pilot light is not staying on. could be dirtly contact on the ignition spark plug or dirty pilot flame need to be cleaned and the unit serviced.
i hope this was useful.
May 28, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
Pilot light stays lit but burners do not ignite
check to see if pressure switch wires are tight and pressure to pressure switch then check safety circuit make sure wires to gas valve are tight
May 23, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Nov 19, 2012 | Heating & Cooling
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
Dec 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Pilot lights but burner won't light. Display continues to read SPK
On these units, the pilot ignitor and the pilot rectefier are the same part. The pilot can be lit, but not be sensed by the rectefier/ignitor. This will keep your burner tray from igniting. You need to replace the ignitor assembley. If it is the same as the raypak digital 406a I charge about $75 for that part, and it takes about 20 minutes to install. Need the part or more help e-mail me. adamh@newconceptchem.com
Oct 22, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Charmglow Patio Heater
The yhernocoupler would snuff the pilot if bad. What ignites the overhead burners? and what regulates the overhead gas supply? Look into this. Too much gas will not light as easily as proper balance gas and air. Even more so in a tower type heater.. Turn the gas on low and the pilot should grab it. Good luck
Jun 05, 2009 | Coleman (5040B750) Patio Heater
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
274 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
