I JUST REPLACED THE DRIVER SIDE LOWER BALL JOINT/CONTROL ARM AS IT COMPLETELY BROKE ON ME WHILE I WAS DRIVING ALSO HAD TO REPLACE CV JOINT AS THAT BROKE AS WELL FROM THE CAR FALLING I ASSUME, HOWEVER THE CREEKING NOISE IS STILL THERE AND NOW A POPPING NOISE? IM SCARED TO DEATH TO EVEN DRIVE THE CAR AS IT JUST RECENTLY BROKE ON ME.
To perform the following procedure, the lower control arm must be removed from the vehicle. Refer to Removal And Installation for that procedure.
NOTE: When installing ball joint in lower control arm, position the ball joint in control arm so notch in ball joint stud is in the direction shown. This will ease assembly of the ball joint to the steering when installing pinch bolt.
CAUTION: Do not use an arbor press to install the sealing boot on the ball joint. Damage to the sealing boot will occur if excessive pressure is applied to the sealing boot when it is being installed.
CAUTION: A replacement ball joint is not pre-lubricated. Properly lubricate the replacement ball joint using Mopar Multi-Mile grease or an equivalent. Lubricate ball joint after seal boot is installed but prior to top of seal boot being pushed down below notch in ball joint stud. Air must vent out of the seal boot at notch when grease is pumped into ball joint, failure to do so will balloon and damage seal boot. Do not over grease the ball joint, this will prevent the seal boot from pushing down on the stud of the ball joint.
CAUTION: After the ball joint is properly greased, clip the end of the grease fleeing off below the hex. The ball joint seal boot is non-purgeable and further greasing is not required and can result in damage to the seal boot.
