Question about Sharp LC46SB54U 46 in. LCD TV
Broken /cracked lcd panel sharp aquos lc52e77u
I want to buy a replacement screen cheap for this 52'Sharp lc52e77u.
My screen has a crack. HELP!!!!!!!!
  • 84 Answers
SOURCE: Sharp Aquos 37 inch. Flat Panel cracked
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv.
I hate to say this but its often cheaper to just buy a new TV.
My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Posted on May 04, 2008
1Guru
  • 61 Answers
SOURCE: Cracked LCD Screen on Sharp Aquos LC37D43U 37-Inch 720p LCD HDTV
Most LCD's just went down in price by around 2-400 dollars. I would suggest buying a new one. The cracked screen might mean that the liquid will ooze out and get worse and worse as it ages. However, it may only have a crack and not get any worse than it is now. If you can live with it and it doesn't get worse, you can view it that way for another 10 years and be fine.
The fact that the LCDs are cheaper now and you only have a 37 inch, you might consider getting a larger one that you have had your eye on for a long time. (Note: even though I am a firm believer in LCD's over Plasma, plasmas are a few hundered dollars cheaper and if you know your children are prone to breaking things... it might be the way to go.)
Replacing the screen is possible, but more costly than the new T.V.
Posted on Dec 12, 2008
  • 8457 Answers
SOURCE: Cracked Sharp LC-46D62U lcd panel.
look up your local repairman they should have part.The part it should cost about $150,labor must ask.
Posted on Jul 01, 2009
  • 87 Answers
SOURCE: Is it possible to get a 46 inch panel for a sharp
If the actual LCD panel is cracked, you don't want to even bother looking for a replacement. It would be either the same cost or more expensive to replace the LCD panel than to buy a brand new one. The other issue is if you are going to attempt to do it yourself, there is a chance that you might inadvertently damage something in the process so you would be out the money you spent on the LCD panel and you would still need to buy a new one. These are called consumer models for a reason. Mass production drops the price of the unit, but replacement parts outside of that mass production sometimes are as expensive if not more expensive than a brand new whole unit and are a lot of time VERY hard to find. LCD's are disposable once the actual panel is damaged.
Posted on Nov 06, 2009
Testimonial: "Thank you I really appreciate your help"
bshldn
  • 736 Answers
SOURCE: Sharp AQUOS 52" 1080p 120Hz Flat-Panel LCD HDTV
Press the menu button and scroll over to the setup sub category. Scroll down to reset and press enter. Select yes and then enter. Select yes again and press enter. The television will turn itself off and then back on.
If that basic reset doesn't work call 877-332-7867 to be walked through the no sound troubleshooting up to an INIT. I cannot put the steps for an INIT into print because any wrong move could erase everything from your television.
Posted on Dec 29, 2010
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Broken screen
If the screen is broken(cracked or shattered) you are done.
part wholesale if available is more than set cost new.
Mar 23, 2012 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Considering buying a used 46'' sharp aquos lcd tv/ mode # LC-46e77u, but the screen is cracked and now needing to know the cost of replacing the screen
Don't buy this tv.The tv LCD screen broken,the tv is junk now,not worth as a whole tv anymore.The replacement of the LCD screen,will cost the same as a new tv.The tv LCD screen panels are limited produced,by the tvs corporation.Will cost the same as a new tv,if require changing the LCD screen panel.
Sep 06, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Nov 06, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Cracked LC37D62U LCD TV
It is broken,The outside is a Polorised film.Like window tint,It is repairable,New LCD screen.But may be cheeper to buy a new TV. GET A EXT.WARENTY!!! will not cover accidents but the new tv's do break alot,and are expensive to repair.
Buy a name brand, NOT RCA "junk" Just a name
no longer a company. Samsung,Panasonic,Sony. If you want to support the USA buy another Sharp. Still a great TV. And made in America. NOTE they make after market screen protectors. GOT KIDS? GET ONE. :) Or even a piece of plexie glass if cash is tight. Hope this helps.
Oct 25, 2009 | Sharp LC-37D4U 37 in. LCD Television
32 inch Sharp Aquos Screen is cracked. Can it be
Yes, however, the Display is as much as a new set.
Oct 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My (sharp aquos lc 52d62u) tv fell to the ground. Image of broken glass and colored lines appear
Unfortunately the panel is cracked internally can't can't be repaired the whole panel has to be replaced. most times the panel will cost as much as you paid for the set. My son cracked ours when it was only 3 weeks old it doesn't take much force to ruin one.
Rustym62
http://www.the-tv-dude.typepad.com
Apr 26, 2009 | Sharp LC-52D62U 52 in. LCD HDTV
Sharp Aquos LC-52D64U Won't Turn On
I have fixed many sharp lcd tv's with a reset. If one appears to have no defects like bad capacitors, fried inverters, broken panel, ect. and the power light is flashing steady or not on at all a reset may help. There is a lot of bad information regarding the procedure though. The correct procedure is to unplug the tv, hold volume down and channel up at the same time and plug it in. Release those buttons then push the power button. Did it start? Great! I have no idea why so many seem to need this. If there truly is a problem this will only work temporarily or even momentarily but many will be fixed for good.
Apr 10, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
52" LCD HDTV w/ Cracked screen
No way. The lcd panel is more then the price of the tv. Sorry.
Sep 04, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC46SB54U 46 in. LCD TV Logo
352 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
