Question about Garden
Engine cuts out when letting clutch out
Engine stalls when letting clutch out in either fast or slow speeds.do not smell rubber burning ect.blades turn when turned by hand. mower is a craftsman 42" with a krohler 15 hp cv 15.s engine....thanks for any help...len
  • 41 Answers
Deck belt and drive belt are seperate. Look under back make sure it not jamed.
Posted on May 28, 2009
  • Greg Hamilton Aug 16, 2011
    my mower, when you engage the blades won't release the brake pads that are used to stop the blades..is ther an adjustment for the pads?
Burning rubber smell after driving 5 miles in 2005 ford escape,also check engine light stays on
Could it be your clutch? It could be slipping., Revving higher than it should when changing gear? Put it in a higher gear when driving at a slow speed like 20 if it is revving when you put your foot to the floor but the speed is not matching it. The clutch could be on its way out.
Dec 09, 2013 | 2005 Ford Escape
Mtdproducts com
This most often happens when you are mowing too much grass at once, or when the deck (or chute if you have a bagger) is clogging for some reason. Sometimes this is made worse by having dull blades. Usually mowing at a slower speed or mowing more frequently will help solve this. If the motor is struggling with the blades, these are usually the culprits. Clean your deck thoroughly, cut the lawn more often, or cut it slower.
In some cases, if your PTO belt may be worn, stretched, or need adjustment. When this happens, the motor will not slow down with the blades but will keep running normally and you may smell a burning rubber smell as the blades slow down.
Jul 16, 2013 | Garden
What would cause a 1989 nissan sentra to smell like burning rubber and then stall out but not over heating
clutch plate to tide ,brakes not release probable or the hand brakes not release right down.,plastic material on the exhaust system .electrical wire shortage .
Sep 22, 2012 | 1989 Nissan Sentra 4 Door
2002 T&C 3.8, 4 speed auto heavy clutch or brake smell
1st thing to check is when you put in gear when cold and again when hot Take off fast ,,the noise if there igoes up and down with the speed and rpm ,,the noise you can hear mostly is the pump in side the gear box is not pushing enough pressure to the Forward Band clutch which drives the car so it has to slip and that is what you can smell the clutch bands burning And the more you can smell it the worse its getting and soon will let you down in a place you dont want to be..
So get it checked out new or as soon as poss
The A/Con clutch also sounds like its worn out.
Oct 12, 2009 | 2002 Chrysler Town & Country
Hi, I have an 1985 Chelsea attic fan. The motor is still working fine, and it is turning the main bolt on which the fan blades are hung. This main bolt turns very fast, at the speed of the motor. The fan...
It is the fan clutch. Like in a truck with a full time fan, it has a clutch that accelerates the fan as it is needed. Your clutch on the fan has probably burned out.
Jun 21, 2009 | Heating & Cooling
TRANSMISSON PROBLEMS
if its manual sounds like your clutch could be slipping does car smell of burt clutch?
check cluth adjustment
may need new clutch
do stall test with hand brake on, foot (heel-toe) on brake and accel pedal to about 2000rpm then let out clutch and car should stall if engine revs go down and engine still runs but you can rev causing slip and you will now smell what slipping burnt clutch is replace it.
if its auto check trans oil level and what does it look like red-good
darker red to black-bad often smells burnt also possibly new trans required.
May 31, 2009 | 2000 Toyota Celica
Garden Logo
240 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
