Question about Refrigerators
Kenmore refrigerator 1068609912 defrost failure
I was able to determine to frig was not going into defrost and the heater and terminator test OK but where is the defrost timer located to verify that it is the culprit. No wiring diagram available. Thanks!!
  • 56 Answers
877-262-1479 for parts. Most defrost timers will be either in the control panel where the thermostat that you adjust temp with is or under the front behind grill cover i think this model it is where the controls are
Posted on May 29, 2009
My ge GSS22WGMCBB is not getting cold eonough - frig reads 60 degrees, freezer reads 38 degrees. What can be wrong? It's 10 years old...should I get it fixed or replace it?
either the compressor isn't running due to a faulty PTC overload relay on the compressor body or a bad compressor itself,you can test the compressor with an ohmmeter between the 3 terminals on the side of the compressor PTC is mounted,if its ok then it can be a defrost problem where its not melting the evaporator ice and blocking the cold air flow remove the inner rear wall of the freezer and test the defrost heater located below the evaporator coil as G.E. defrost heaters are notorious for failing,if its ok,then the defrost terminator on top of this coil can be bad(open)to test this component it needs to be below 15 degrees temperature to show good(closed) if ok then the mainboard located in the rear back of the unit can be defective because it controls all the units functions
Aug 25, 2012 | GE Refrigerators
How to test defrost timer
we ll see how u need to check the defrost timer....
Before testing the defrost timer, unplug the freezer to avoid an electrical shock hazard.
A mechanical defrost timer controls the defrost cycle of the appliance. In older models, the timer runs continuously and roughly every six hours, shuts off power to the cooling system and sends power to the defrost heater. In newer models the timer advances only when the compressor or defrost cycle is running - an improvement for efficiency. As the timer advances, power to the heating element shuts off and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrost timer is usually found behind the front grill of the freezer. It may also be found behind a cover plate inside the freezer, in the temperature control console, or behind the freezer near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Test the timer for continuity using a multitester. Set the multitester to the ohms setting X1. The timer has four terminals. Locate the common terminal, it should be labeled "3" or "C". If the terminals are not labeled, determine which terminal coincides with the common wire in the connector plug; it is usually the white wire.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multitester should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
Locate the timer switch and turn it clockwise until you hear it click. Now retest the timer as you did above. One pair of terminals should indicate continuity (possibly two pairs). At least one pair should give a reading of infinity. Note however, one of the pairs that showed continuity in the first test should now read infinity and one pair that read infinity should now show continuity. If the defrost timer does not pass these tests, it is likely that it should be replaced.
Before testing the defrost heater, again make sure u unplug the freezer to avoid an electrical shock hazard. The defrost heater is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear or bottom inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. There are three primary types of defrost heater elements; exposed metal rod, metal rod covered with aluminum tape or a wire coil inside a glass tube. All three elements are tested in the same way. The heater is connected by two wires.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Test the heating element for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading somewhere between zero and infinity. If the reading is not between those two extremes the heating element should be replaced.
May 14, 2010 | Maytag MSD2756G Side by Side Refrigerator
Ice forming on back of freezer , refrigerator side not cooling GE modelgss22wgpe bb
You frig is not going through the defrost cycle. Locate the defrost timer and advance it to the defrost cycle.(one click). Empty the freezer and remove the rear panel. See if the defrost heater is starting to get hot. Located at the bottom of the evaporator. If getting hot, replace the timer. If not getting hot, unplug the frig and check the resistance across the defrost timer(should be a closed curcit when cold) and across the heater. If "0" resistance, replace heater.
When replacing the heater alwarys replace the defrost thermostat at the same time. Will save you work in the near future.
Dec 28, 2009 | GE Refrigerators
KitchenAid KSRS25QXAL10 Side-by-Side (1992) won't defrost
HI. There are two causes here, in this situation. The most common will be a faulty defrost timer, or adaptive defrost control board. The defrost mechanism will vary from unit to unit. Most newer units will be equipped with an defrost control board. This will be located in the control housing, just above the heat shield, in the upper right had side. Older models will have a standard defrost timer mechanism. If this device fails, the evaporator heater Assembly will not receive the command to defrost the coil, on time. The easiest way to isolate the cause, will be to test the heater element. If the element is functional, the defrost timer/board, will be the culprit.
Defrost heater assembly test procedure:
The defrost heater is usually located at the back of a side by side freezer or under the floor of a top freezer. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice-maker and the inside rear or bottom panel of the freezer, to access.
The panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. On some older top freezers it is necessary to remove the plastic molding to access the freezer floor. Removal of that molding can be tricky, so try not to force it, if possible. If you decide to remove it, you do so at your own risk. it will break, if forced. Warm it first with a warm towel, or hair dryer, set to low heat.
The heater is connected by two wires. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the heating element for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading somewhere between zero and infinity. Because of the number of different elements we cannot tell what your reading should be, but we can be certain of what it shouldn't be. If the reading is zero or infinity the heating element is definitely faulty, and should be replaced.
TESTING YOUR DEFROST TIMER MODULE
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically. Test the timer for continuity using a multimeter. Set the multimeter to the ohms setting X1. The timer has four terminals. Locate the common terminal, it should be labeled "3" or "C". If the terminals are not labeled, determine which terminal coincides with the white wire in the connector plug.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multimeter should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
Locate the timer switch and turn it clockwise until you hear it click. Now retest the timer as you did above. One pair of terminals should indicate continuity (possibly two pairs). At least one pair should give a reading of infinity. Note however, one of the pairs that showed continuity in the first test should now read infinity and one pair that read infinity should now show continuity. If the defrost timer does not pass these tests, it should be replaced.
Nov 19, 2009 | KitchenAid Refrigerators
Ice forming on rear of freezer wall
The best way to determine what has caused a non defrosting GE electronic control model is to first access the control board. Jump terminals line power to defrost, (J4 and J9). An amp probe should be placed on this jumper wire to determine current draw of the defrost circuit. A three amp draw is what is normal for this circuit. This will eliminate checking behind the evaporator cover to determine a defective heater or over temp device (defrost terminator). Note: This test is only to check the defrost circuit. It does not initiate a defrost cycle. If the unit is in any other cycle than defrost, that cycle will continue to operate as well.
May 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Testing if Fault is Comming From Defrost Heater
You check for continuity at each end of each heater.If is ok you have a bad defrost timer or abad defrost terminator(it 'll close when reaches about 30 degrees).
Apr 17, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
My ge model GSS22JFMCWW has frost on the inside of the freezer. I understand it to be a problem with the defrost thermostat, heater or timer. Is there a way to test each unit to see which is bad? Can I...
Jan 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge side by side Ice built up in freezer now fridge not cooling!
Jan 06, 2009 | GE GSS20IEP Side by Side Refrigerator
Can't find the defrost timer to test my fridge CAMCO side by side
yes the ice buildup is coz of a problem in the defrost cycle... and u wud be required to test all the three components.....
first we ll see how u need to check the defrost timer....
* We have received two reports of cases in which only one pair of terminals shows continuity and when the timer is advanced, the same pair still shows continuity. For these isolated cases, this was reported to be the correct operation of the timer. At this time we have not been able verify this case. This may indicate a specific model or models that use a different wiring configuration than discussed in this article. Also, note that this article applies to mechanical defrost timer controls and not electronic or adaptive defrost controls.
Dec 10, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
Kenmore side by side refrigerator not cooling
Check inside back wall of the freezer for frost buildup. It would be a sign that the defrost system is not working and the coil inside the back wall is frozen over stopping air circulation to the refrigerator.
Defrost system has a timer that energizes a heater and a defrost termination switch which shuts off the heaters when the coil is warm enough for all ice to be melted. If you have the frost, locate the defrost timer and turn the clutch head screw clockwise SLOWLY until you hear one audible click, the compressor will shut off and the system will be in defrost. After 18-22 minutes the refrigerator should restart automatically. If it does not restart after 25 Minutes turn the timer screw again to the second click. Refrigerator will then start. Replace the timer.
If it restarts after the 18-22 minutes and does not defrost ether the heater or defrost thermostat is bad.
Jun 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
161 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
