Brand new Miele W3740 washing machine - vibration
Arrived today, unpacked, removed transit rods , made sure that the machine is sitting level (used spirit level) and ran first water only cycle. So far so good. Put in normal load of clothes and the machine vibrating very badly on spin cycle. Its sat on a chipboard floor with plywood sheeting then lino floor covering. Our previous machine ran for 15 years without vibration problems on this same spot on the floor. Have I missed something? Is there anything that I can do to resolve this vibration.
Any advic would be much appreciated.
    Top Expert:
  • Washing Mach... Master
  • 49,974 Answers
If it is a top loader machine , use the spirit level across the top of the agitator not across the lid as many lids are now sloping a bit
make sure that all of the transit packing and bolts have been removed as per the user manual in the installation section
still vibrating , get a technician out for a warranty inspection
Posted on Apr 30, 2017
    Top Expert:
  • 78,936 Answers
Call for warranty repair.
SOURCE: machine vibrates terrible on spin cylce
Another suggestion, I don't know anything about snubbers and all that. But I had a few machine want to walk across the floor. Several repairmen and other people had told me to buy a peice of plywood, roughly 27"x27" and put it under the machine. It worked for me. I guess the idea is that the subfloor in your new house flexes cuasing the machine lift and walk. I have heard of brand new machines doing this in houses with certain floors. There is an antiwalk kit that is sold too the kit is very similar to a horse pad, a thick very stiff compressed rubber mat. The kit being a solution to aesthetic problem of the plywood. (if you think the plywood is ugly)
Posted on Feb 02, 2007
SOURCE: Miele transit rods stuck
My husband was able to pull it out .
Posted on Feb 28, 2008
THENTHEREWER
  • 131 Answers
SOURCE: Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Posted on Nov 16, 2008
SOURCE: excessive vibration during spin cycle
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Posted on Mar 07, 2009
NiftyInsight
  • 15 Answers
SOURCE: Bad vibrations/shaking with LG washing machine WM2032HW
What's the exact model of your washing machine? I'll need this to get you exact part numbers.
If you're looking for a quick and cheap fix that works. Try installing a rubber anti-vibration pad under the washer. I've had the best luck with a pad called Silent Feet. They are pretty hard to find in stores but Amazon.com carries the full line of Silent Feet anti-vibration pads. They will provide you with the best results short of replacing the full shock isolation assembly in the washer. And they cost a lot less.
Posted on Apr 04, 2010
How do I fix a F53 fault on a Miele W3740 Washing Machine
First, unplug the washer for minutes then plug in and see if it solve the problem, if not then check the carbon brushes on the motor. These are a part which is expected to wear and when they do the motor cannot rotate the drum, which means the speed sensor thinks something is wrong and throws the error.good luck. Fixing an F53 on Miele washing machine
Nov 02, 2017 | Miele Washing Machines
I have a brand new maytag 4000 series front loader washer that shakes across the floor while on spin cycle. it is level and balanced. not sure what is goin on.
This sounds like the transportation support rods have not been removed. A new machine will have two or more steel rods supporting the drum to prevent damage during transportation. These rods MUST be removed before the machine is used, otherwise the dampers that prevent excessive vibration will not be effective.
The user manual should provide instruictions for removal of the rods. They are normally accessed from the rear of the machine and usually will be labelled so that it is clear how to remove them. They pass througn the chassis of the machine and should be unscrewd and pulled out from the rear.
Jan 22, 2011 | Maytag MAH6700AWW Neptune Front-Load...
I left the transit bolts in our "brand new" zanussi washing machine and am afraid to use it as I do not know what damage might have been done.
Highly unlikely any damage will have been done so long as it hasnt been in use for a long time (weeks).
In a front loading washing machine, most of the mechanicals inside are held between springs at the top and dampers at the bottom. The transit bolts are used to minimse how much movement can ocour whilst the machine is in transit as excessive movement could damage the springs/dampers. When they are removed, normal movement of the mechanicals helps keep the machine stable and minmises vibration.
So, the worst that happens when the machine is used with the transit bolts in place is it vibrates alot, and possible moves about.
Remove the bolts as soon as possible and it should be fine.
Oct 04, 2009 | Zanussi ZWF12070 Front Load Washer
My front load washing machine shakes violently in the final spin cycle. It is brand new and sits level.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Also - be sure the drum locking (transit) pins were removed by the installer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 03, 2009 | Kenmore Washing Machines
Miele W828 Frontloader vibrating more.
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Jun 17, 2009 | Washing Machines
Transit struts need taking off a miele w3748
The struts are just turned about 90 degrees and pulled from the rear - make sure you keep these in case the machine is to be moved - they need to be reinstalled
Nov 27, 2008 | Washing Machines
Feb 27, 2008 | Miele Washing Machines
Kenmore elite washer model 110.26922503
usually ther is a transit bar that has to be removed that holds the gerbox in place
chek that it has been pulled out from the back
Nov 10, 2007 | Kenmore 15864/15862 Top Load Washer
A walking machine
ADDITIONALLY,CHECK AND MAKE SURE TRANSPORT BARS ARE CORRECTLY REMOVED.NOTICED ON MANY OCCASIONS TO THAT IF WASHER IS IS USED ON TYLED FLOOR, IT WILL SLIP AND SLIDE REGARDLESS. ON A MORE SERIOUS NOTE, CHECK IF STABALISER BLOCK HASNT POSSIBLY WORKED ITSELF LOOSE.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
517 people viewed this question
Top Washing Machines Experts
