Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
The TV will not turn on and the standby/timer red light is flashing 6 times. I have tried unplugging the TV for 1 minute then plugging back in with no improvement. I unplugged overnight and plugged in with no improvement. I tried turning the TV off and on while holding down the reset button on the remote control with no improvement. could it be a lamp problem? I have problem,the indicator blinking 6 times,ihave only 5v stand by
6 blinks, then a pause, and then 6 blinks again would mean Low B OCP/OVP (Overcurrent/Overvoltage)". This could mean that either the +5 line is overloaded (A, B boards), or that the +5 line is shorted (A, B boards).
Commonly, this is fixed by replacing the thermal fuse. You will need to remove the lamp, and then remove the fuse (it may be behind the lamp), and get it replaced. This in most cases will fix the problem with the 6 blinks.
It may be safer to allow a qualified TV service person to do this however just in case there are dangerous voltages.
Hope this is of some help and that you get your TV working again soon!
Best of luck,
nLinked
Computer Support Services
Posted on Jun 08, 2009
Light blink 6 times
Your mainboard is gone bad, happened to my tv and they had to replace it.
Oct 09, 2012 | Sony KP-53HS30 53" Rear Projection...
Tv will not turn on, red flashing light comes then turns off
tv will not turn on, red flashing light comes then turns off.
light flashes six times.
Aug 15, 2012 | Sony KP-53HS30 53" Rear Projection...
Tv flashes red then shuts itself off after only on for 3 min
I have not repaired this particular model. But sometimes there is an IC they refer to as a standby IC. It may also be known as a controller IC. I call it the powerline regulator. And in one case the older Sony Projection TV had an audio output IC with a standby built into this IC. So,this advice is refering to a standby IC. And this IC may be in another form already mentioned. Please visit a Sony Tech. The work inside a projection TV is very complicated, you will need to see the specialist. Give them this note and go from here. Let me know how they handle the repair.Thanks for asking and good luck!
Aug 02, 2010 | Sony KP-65WS500 65" Rear Projection...
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Feb 10, 2009 | Sony KP-57HW40 57" Rear Projection...
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Kp53hs30 light flashing 6 times
Hello worksofgrace,
I gave this advice earlier, but since your problems is just about the same, I hope this helps.
This problem is linked to a power supply issue. The SSB is part of the power supply chain and will cause system failure if the board is defective. I have seen to many of these type of modular power supply boards fail. The shutdown circuit is detecting excessive voltage/current, and in the process of turning off the set it may have blown something else. I am begining to suspect a design flaw, which happens from time to time. I would suggest having a qualified TV repair person take a look at the TV and work on it.
Thank you,
Shuttle83
Jul 27, 2008 | Sony KP-53HS30 53" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
Dec 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
187 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
