Question about Vehicle Parts & Accessories
HOW DO I GET MY REMOTE OUT OF SLEEP MODE
THE SCREEN SHOWS ZZZ LIKE IT IS IN SLEEP MODE
Prestige car alarm car will start but red light come on when key in ignition and shut off.
Posted on Aug 09, 2010
Our Sony TV at work will not give us the option to turn off sleep mode permanently.
Go into settings, there is a option to turn the sleep mode on or off.
Oct 12, 2016 | Sony Televison & Video
My screen symtoms are a little different on my L1975NW.
I am guessing the LED power indicator blinks green then becomes steady when the screen "turns on" (shows video). The problem is most likely a failing backlight power supply. That's why there is a 30 minute delay. Try to disable sleep mode and see whether that helps.
Aug 30, 2012 | Westinghouse L1975NW Monitor
My tv will turn off by itself every 30 mins and has a blue light that blinks 12 times! how do i fix this problem?
yr sleep program is on. Find this in the menu and turn off. It is also on yr remote, u can turn it of from that just take yr time and work out which is the sleep mode button and click until the screen shows off or something similar. cheers
Aug 14, 2012 | Pioneer Elite PRO-950HD 42 in. Plasma...
My Proscan 19LA20Q Keeps going to sleep mode after my sister touched something on the remote. The Blue screen and the source flashes on for a few seconds then the light goes orange and the screen goes...
ur sister possible turned the sleep mode on.......check on ur remote that is is off......if this problem persist u have to call service to fix ur problem
Nov 20, 2009 | Proscan 19LA20Q LCD TV
What shld i do if asus laptop is in zzz mode and it wont turn on?
Try this simple solution- press on the power button for a very long time, until the laptop stops working.
After the computer shuts down, turn it on again and look for the sleep settings, sometimes the computer is too eager to turn off the display. You'd be surprised how many computers have troubles waking from their sleep (maybe they need to call the charming prince). Anyhow, check the settings for the computer's sleep. I always ensure that my laptop won't independently fall asleep, always by button.
Nov 05, 2009 | ASUS Computers & Internet
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
This TV has a sleep mode
There are two ways to solve this, but both will require using the original remote for the Magnavox. The original remote has a SLEEP button - press it until the screen says Sleep DISABLED or Sleep OFF.
Or make sure the TV is in TV mode, and Press Menu --> TV Steup --> Sleep Timer --> change to DISABLED
-Tha Mp3 Doctor
Feb 20, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Cannt get tv to change chanel
Check the mode the tv is on (Use "Source" button on remote to change modes). There are several modes to choose from.
Jul 16, 2008 | Akai LCT3201AD 32 in. LCD Television
Trying to use sleep mode, no manual or original remote
do a google search on the model of your tv..and you will find the original remote available most of the time for only a few bucks..........
Feb 03, 2008 | Philips 55PW9363 55" Rear Projection...
Vehicle Parts & Accessories Logo
513 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
