Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
Cant Run WD Sync on new HP with Vista Premium - Get message Can't load the selected program
I have a new HP with Vista Premium and when I try to run WD sync I get a 'Can't Load the selected program or file' message. I have not used WD sync before, only used it for backup.
5 Suggested Answers
SOURCE: WD Passport
i need the instalation
Posted on Oct 05, 2008
  • 916 Answers
SOURCE: WD passport 320GB Can I use it as storage, not backup?
You can use it as storage if you would like. You can also delete files once they are put on the passport. When it is connected to the computer open my computer and it will be listed there. You can use it as storage by copying files into this way rather than syncing it. Syncing it could cause you to lose files.
Posted on Apr 29, 2009
  • 181 Answers
SOURCE: Cannot sync from Western Digital Passport 320gb HD
try and format using your vista or xp tools,right click on the hard drive go to format and format it as a ntfs drive.
Posted on May 29, 2009
Getting message from computer
To run DVDVideoSoft you will administrative right to your PC, if you have administrative right to your PC.
Start DVDVideoSoft by Right Clicking on DVDVideoSoft and selecting Run as administrator
Dec 06, 2011 | Microsoft Windows Vista Home Premium...
Navman n40i smart st compatability problem with vista.
Are you not able to run the activesync program despite the Vista warning? Did you try running it in compatibility mode? What happnes when you try to connect with sync center (what happens...any error messages)? Regarding the mobile device centre...did you check that McAffe and windows firewall is not blocking it from internet access?
Jan 26, 2008 | Navman NavPix N40i GPS Receiver
Usb device not compatible message
the message is probably saying that you do not installed he correct driver...Go to the HP support and download the correct driver..To do that select in the list the exact model and exact operation system for it ..If you use a newish operation system ..and it only have drivers for windows Xp or vista ..try to install the newer one ..(vista in our case ) ..and after install click right on the program ..and select properties..and compatibility ...then select to run in compatibility with the operation system your driver was made for ..If the driver is for vista ...select vista if it is for XP ..select xp ..and you have a 50% chances to work ..
driver ( new one without issues on amd cpu on windows 7)
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=3737195#N189
If you have the os on 64 ..select the correct operation system in the list first ..this one is for 32 os..
read this first ..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03030583&cc=us&dlc=en&lang=en&lc=en&product=3737195
Oct 26, 2011 | HP Photosmart Premium C309A All-In-One...
Big Mutha Truckers won't run with windows 7 home premium
SORRY BUT YOU CANT TURN IT IN VISTA
TRY TO GET XP SP3 ITS MUCH BETTER AND RELIEBLE AND YOU CAN TURN ALL OF YOUR GAMES WITHOUT PROBLEMS
Jun 08, 2010 | Empire Interactive Big Mutha Truckers for...
Cant download a pic disc onto a program. cant transfer files
. Go to Sharepod Folder. Double click on Sharepod.exe. If message “Failure to
initialize” appear on your screen, you need to download the Microsoft.NET
Framework 2.0 to run sharepod. Note this program is installed by default under
vista.
Please be careful not to run Sharepod and iTunes simultaneously as iPod might get
out of sync with both software.
Disable iTunes
  • Ensure Ipod is connected to your computer. Select removable disk in My Computer,
  • Open iTunes if not set as default. Select iPod and click Settings and disable option Open iTunes when Ipod is attached.
  • Then, scroll down and uncheck Options.
  • Next step is to Enable disk use and click Apply.
Dec 02, 2009 | HP Computers & Internet
Need to use HP Deskjet5550 to print off laptop
Since Hp have Vista driver to your printer...to install the driver...do not plug the printer...install the driver that you downloaded (run the program as Administrator)..after you install, if the installation ask for restart..restart your computer...after restart and the whole system finish his task on loading driver and dll ..then plug in your printer...it will pop up message found new hardware. click next and choose automatic find the driver.
what Cable are you using to connect?
USB a and b?
parallel port to USB? if this you need to download the driver too.
Good Lock
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
Cannot upgrade windows vista home premium from disc
Check the programs that vista says it can not update. They may be incompatible with Vista. You can find this out by running the Windows Vista upgrade advisor available for free at microsoft.com. If you really want Vista & can do without the offending programs you can uninstall them & then run the upgrade. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | Microsoft Windows Vista Home Premium with...
Cannot load "arthur" with widows vista home premium stops installing
Hello... Please go thru this. Souce:http://www.ataricommunity.com/forums/showthread.php?t=573497
I may have a work around
It is a way to give admin privs to the msi file
First, create a file called Arthur.bat
- Open a folder, say C:\temp
- Right-click and select new, Text Document
- name it Arthur.bat
Next, edit the file
- right click the file and select edit
- put this in the editor ... msiexec /a d:\Arthur.msi
- save and exit
Then, right-click the file and select "Run as administrator"
Worked for me.
There is another msi file (ISScript11.msi) on the CD which I didn't run which may be needed ? But, I managed to play through the tutorial/start so ... we w ill see.
So, it is a permissions thing. Hopefully this will get passed on to the developers and they can resolve it tout-de-suite
Nov 02, 2008 | Atari Arthur & the Invisibles for Windows
When I run System Recovery DISC the programme tells me '' The Disc I have loaded is not empty' yet is a Disc I purchased specially for creadting recovery discs. I am using a HP PAVILION Computer M...
A system recovery disk is for recovering a failed hd. try booting up on the recovery disk. If it works U will loose all programs and data loaded since its creation.
May 26, 2008 | HP Computers & Internet
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
512 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
