Question about Amana ABB1927DE Bottom Freezer Refrigerator
Freezer on the bottom
Last spring frig went out-freezing working. Was using freezer. In Sept. frig starting working again and was fine all winter. Now, frig not working properly again. Am reading others having the same problem--
  • nortonlc May 30, 2009
    Thank you for responding. Unfortunately, I keep getting the same response that I get from Amana. No model found???
    BC121VW
    Linda
  • Amana Master
  • 4,655 Answers
Because there are many models like the model number listed above your post I will need you to confirm the model number on the refrigerator. The photo below shows were to look for the model number. Some like yours have a simple defrost system and some have circuit control boards. Everyone has these problems with every brand, Your model is Amana and also a Maytag brand. Let me know so I can help you get this going thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 29, 2009
  • John Tripp
    John Tripp May 30, 2009
    Is your model like the ABB1927DE Amana?
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a GSL25JFPA BS that the frig side will not cool properly. Repalced the mother board. t stat in freezer and thermistor in frig. Freezer works fine. Damper will open when first plugged in but closes...
Unplug the refrigerator and then plug back in. Using multimeter check between J3-1 and J3-4.
Must be done within 10 seconds of starting. You should have 6 VDC. If you do replace damper, if not replace motherboard.
Jul 06, 2011 | GE GSL25JFPBS Side by Side Refrigerator
I have a ge side by side and the frig part is working fine but the freezer part is not freezing the top part of the freezer where the ice maker is. the bottom part of the freezer is freezing just fine....
It could be that the defrost assembly is continuously activated, since it is at the top of the freezer section. This could be a control board problem or the defrost assembly is shorted.
Jun 07, 2011 | Refrigerators
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore side by side frig not cooling in frig comparment and
Something has failed in the defrost circuit-
Defrost thermostat
Defrost heater
Defrost timer
Reply back if you know how to diagnose electrical circuits, and I'll help you further.
Feb 01, 2009 | GE GSS20IEP Side by Side Refrigerator
Freezer doesn't freeze in winter?
Domestic refrigerators nowadays are designed not to operate at temperatures less than 45 degrees. First, if it's 45 degrees in the house, people probably are not living there. 2nd, 45 degrees keeps food refrigerated. 3, if people are not living in a space, then they don't need to keep frozen food.
This is a result of the changes in refrigerants we've been going through since 1992.
If you want an outdoor freezer, buy one, and make sure it's designed to be used in a non conditioned space.
Jan 26, 2009 | Frigidaire FRS23KF7AB Side by Side...
Refrigerator has uneven temperature from top to bottom
if frost is building up in your freezer you have a defrost problem,is the freezer fan working?can you remove the freezer panel so you can check the defrost heat and defrost sensor?and last check the defrost timer in the frig. or on the front or back of frig.,let me know what you find-mike
Nov 15, 2008 | Refrigerators
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Frig side by side problem
I rolled the frig forward enough so I could unplug the power cord from the outlet. Then
I removed the freezer back panel and found the evaporator coils completely encased in frost. I used hot water in a 20 ounce sqeezable water bottle to remove the caked frost from the coils. I used the back panel as a chute to route the water into a large square bucket I placed on the floor right in front of the freezer. I then disconnected the defrost heater and checked continuity with my meter on the Rx1 scale. Meter needle did not move when connected across the heater indicating that the heater was bad. Called the local parts supplier and gave them the numbers off the old part. They had it in stock for $27.31 so went and picked it up, plugged it in, put in the mounting screws, replaced the freezer back panel, and plugged the frig in. I turned both the freezer and frig thermostats to their normal position. Four hours after my better half got all the food back in the freezer and the frig, the temperature in the refrigerator was 36 degrees.
Feb 28, 2008 | GE GSH25JFR Side by Side Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
153 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
