Home | Dell | Dimension 4600 PC Desktop | Uninstalling vista
Dell Dimension 4600 PC Desktop
Problem for Dell Dimension 4600 PC Desktop
Uninstalling vista
By sherfayed on May 28, 2009
actually i would like to uninstall it..it keeps showing up with an error message..
Clarification Request
Posted by DickCanFixIt on Jun 30, 2009
You don't "uninstall" an operating system. You wipe the hard drive and start over. Before you do that, do you have another operating system available? Windows will not work without a valid product key. You cannot use your Vista key to install XP. A new copy goes for anywhere from $50 - $200. Good luck.
Best Solution
posted on May 28, 2009
Helpful)
vkyhunk
Rank: Guru
Rating: 91%, 558 votes
Well i Suggest That You Should Install Windows XP On This System Because The Configuration Of Hardware Would Mess Up Everything In Case Of Windows Vista Installation..
There are 2 ways of UNINSTALLING WINDOWS VISTA
1) Using MS-DOS PROMPT and for that u need to have good expertise with the MS-DOS so that u can RUN DEBUG COMMAND on the hard drive
2) Method Is Easy .. it is to install WINDOWS XP and after its installation WINDOWS VISTA would be uninstalled
Temme if u need HELP in re-installing WINDOWS XP....
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
SimpleText
Rank: Guide
Rating: 93%, 5 votes
I would suggest downloading a free boot CD image such as UBCD or Hiren's Boot CD, burn it to a cd and boot with that, those both contain utilities that will let you erase the drive completely allowing you to install a different operating system.
You can get UBCD and more info here: http://www.ultimatebootcd.com/
Good Luck!
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 4600 PC Desktop
Questions and Unsolved Problems for Dell Dimension 4600 PC Desktop
Do you recommend Dell Dimension 4600 PC Desktop?
Answer
Answer
my system restarts immediately after i shut it down.
Answer
I have one of these from about 2 or 3 years ago. I have lost the driver c.d. for this antena Wave RV... (More)
Answer
Hello, my Dell Inspiron 530S is not starting it is giving me this message. Technical... (More)
Answer
i have a westinghouse laptop model nb-12w2 and i need the recovery disk
Answer
When i turn the tower on the fans start then a little red light flashes but then it turns off after... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Dimension 4600 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 413
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
